moe1965 752 #1 Posted July 16, 2019 Can a carburetor from a 12 horsepower Kohler be put on a 10 horsepower Kohler and work or are they specific for each engine. Share this post Link to post Share on other sites
ebinmaine 70,789 #2 Posted July 16, 2019 I don't know if they are the same all the way from the 60s up but if the bore is the same size and the linkage lines up okay, I'd use it. I do know that there's a difference between 12 and 16. About 12 and 10 should be compatible. Share this post Link to post Share on other sites
953 nut 57,969 #3 Posted July 16, 2019 3 hours ago, moe1965 said: Can a carburetor from a 12 horsepower Kohler be put on a 10 horsepower Kohler and work or are they specific for each engine. No problem, you may need to adjust the mixing screws a slight bit. 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #4 Posted July 16, 2019 6,7,8 HP same carb, 10-12 HP same carb then 14-16 HP same carb... 3 Share this post Link to post Share on other sites
