TimC121
c121 question
TimC121
when you hook a tiller assist spring to the tractor where to hook the spring? I have the flat axle brackets should I look for a axle bracket made from angle iron that has extra hole for the spring?
gwest_ca
You could but may be easy for you to make one. Use angle with the same dimensions as the flat bar but longer. I do not have one to know the original length.
Still available from Toro but a bit rich. Item #33.
https://www.partstree.com/parts/toro/accessories/97-36tl01-toro-36-tiller-1979/tiller-36-in-92-cm-vehicle-identification-number-97-36tl01_2/
Garry
