Countdown To Christmas!
huey5491
kent clutch pedal goes all the way down
huey5491
i have a 315-8 and the clutch goes all the way flat level with the foot rest, any idea on what may be wrong
The Tuul Crib
Do you mean as you are sitting on the
tractor it comes back towards you?
gwest_ca
Pin #13 may have sheared allowing #10 arm to rotate on the cross-shaft
https://www.partstree.com/parts/toro/mowers-lawn-garden-tractor/73450-315-8-toro-315-8-garden-tractor-sn-220000001-220999999-2002/clutch-assembly/
Item #13 is part number 933190 and is a 3/16" x 1-1/4" spiral pin.
Garry
huey5491
It lays flat as it is pushed forward
huey5491
I will check on the pin
huey5491
the pin was broke, thanks for help
stevasaurus
@huey5491  First...welcome to Red Square.  :occasion-xmas:  2nd...when you post something, it really helps everyone if you give a title description.
