Ksaunders
Types of oils
Ksaunders
Hello everyone i need some help i just purchased a wheel horse 520 tractor used. I know nothing about them it has 650 hours on it. Could someone tell me what type of oils  and filters i should use for the engine and the hydrostatic transmission?
lynnmor
:text-welcomeconfetti:  I see you are new here.
Here is the owners manual for a 1993, all years are about the same.  1993 520H
I use SAE 30 year round in the engine, and 10W-30 in the transmission.  Use any good brand, but if you can find oil with a rating lower than SN it might give better protection, for example Kohler has oil that might be a bit better.    I use 122-0800 Onan or LF3338 Fleetguard engine oil filters.  For the transmission, I use the NAPA 1410 hydraulic filter.
Be sure that the rubber grommet is in place around the engine oil filter.
Edited by lynnmor
Ksaunders
Ynnmore thanks so much i had been looking at toro 500 hydro. I guess it would be ok to use mobile 1 10w 30 in rear under the seat
dcrage
A lot of people use Mobil 1 in these transmissions.
Ksaunders
Thanks alot guys
The Tuul Crib
:text-welcomeconfetti:to:rs:
:wwp: !!  I use 30 w shell rotela in the engine.
Ksaunders
Ok, thanks tool crib
Ksaunders
Is 10w 30 synthetic oil from mobile 1 a good choice in transmission
