GetEmJohnnyBoy
Wheel horse identification?
GetEmJohnnyBoy
Hey boys, I just inherited this Wheel horse and know nothing about them, yet. Is there any way I can get some identification on this Wheel horse? Its obviously not original and I Dont know what to look for but I want to restore it back to condition! I don't have enough room for more pictures sorry
GetEmJohnnyBoy
GetEmJohnnyBoy
Here are some more photos, I just found that tag. If someone could help me identify the year that would be amazing
gwest_ca
Welcome to the forum.
6 = 6hp
5 = electric start (0 = recoil start)
5 = 1965
Already added your serial number to the list. Click on the picture
Garry
AMC RULES
1965 Model 655...
6=6HP Tecumseh...
5=electric start...
5=1965.
From the model list...
655 1965 Lawn & Garden Tractor 655 4-Speed Tecumseh H60-75117D 6 Wheel Horse 5049
GetEmJohnnyBoy
6 = 6hp
5 = 1965
Garry
Thank you kindly, you helped me a lot
GetEmJohnnyBoy
56 minutes ago, AMC RULES said:
1965 Model 655...
6=6HP Tecumseh...
5=electric start...
5=1965.
Thank you kindly, I'll have pictures during the restoration for you!
ebinmaine
:text-welcomeconfetti:
You'll find a ton of info and great people here.
Please do keep us posted.
Sparky
Well according to the hood it has a 426 HEMI in there....she must be a race tractor :helmet: !
  Just kidding....and.... :WRS:
  • Haha 3
  • Heart 1
ebinmaine
Don't be giving us any bright ideas
500 horse power Wheelhorse.... hmmm....
  • Haha 3
SylvanLakeWH
  • Heart 1
Achto
:WRS:
Now that would be a true short frame with a big block.:D
  • Haha 4
ebinmaine
4 minutes ago, Achto said:
:WRS:
Your next build??
  • Haha 1
953 nut
:WRS:
:text-coolphotos:      Looks like a new steering wheel and a little TLC will make it a good looking :wh:.  If you want a nice new seat cover @BOB ELLISON can fix you up with a nice one.
GetEmJohnnyBoy
I just sent Bob a message. I wish it had the 426! That day was long gone lol. The motor is not original in it, its a pull start Briggs with a homemade air filter. I got it sputtering yesterday, the carb needs gone through and the gas tank replaced. I'm not sure how I'd remove rust from the interior of a gas tank.
ebinmaine
That Briggs probably has an updraft carburetor.that Briggs probably has an up draft carburetor. The trick with those is just like any other carburetor, you needs to be cleaner than clean to run right. This ethanol gas issue is a big one for those carburetors.
When you order your carburetor kit be sure to get a new Main needle. If you've never dismantled one of those carbs, there are great videos on YouTube. Be conscious that the main needle can be challenging to remove.
Other than that they are pretty straightforward.
Removing rust from the interior of a gas tank can be done fairly easily with a handful of course fish tank gravel or small nuts.
Remove the screen from the bottom and block that hole with tape or something.
Put the gravel or whatever you have in the tank and shake it gently approximately forever and three days or you can bungee it to the side of a tractor rear wheel and drive that around for a while.
  • Haha 1
GetEmJohnnyBoy
Hhahaha had me dying laughing! I would be lying if I said I thought of that haha. I sure will. I have quite a bit of time on me rebuilding Briggs from my youth go kart days, although it's been a minute since I've rebuilt an updraft.
ebinmaine
We have a lot of fun rebuilding these tractors and working them as well. Might as well add every little bit we can, right?
  • Heart 1
adsm08
I added equal parts boiled water a super clean into my tank, added a foot long section of chain, and shook that sucker like a pissed off baby with a rattle.
Did that a few times until it stopped coming out nasty color. Then I replaced the sediment bowl.
  • Haha 2
ebinmaine
I like that idea
  • Heart 1
adsm08
1 minute ago, ebinmaine said:
I like that idea
It worked out pretty well. It took all the old evaporated gas goo out pretty quickly.
ebinmaine
Also much easier to remove than lots of individual pieces
  • Heart 1
pfrederi
However you clean it it will start rusting again.  I would recommend Eastwood gas tank sealer or POR 15 Gas tank sealer.  i did the tank on my Case VAC about 14 years ago still clean inside and no rust.
https://www.eastwood.com/gas-tank-sealer-kits-eastwood-gas-tank-sealer.html
Edited by pfrederi
  • Heart 1
dells68
I’m a Kohler man.  I’d find an 8hp Kohler with a starter generator and repower that baby as an 855!  I just put a piston and rings in Emory’s 855 that was good at fogging mosquitoes.  Found very little wear, even to the bore and it runs like a scalded dog now!  Good for another 50 years!
  • Heart 1
adsm08
I agree, almost all the problems I have had with my Kohler 8HP are ones I caused myself by touching, bumping, or adjusting things that I should have left alone. Most of my issues started when I tried to replace the muffler and knocked the throttle ring and governor loose while trying to get the old pipe out of the head.
Personally, I'd like to repower to a 10HP, but its gonna be a while.
  • Heart 1
