slapshot
B80 help!
slapshot
I am helping a friend with a B80 Model 71-08K801 4808, s/n 7329. I need the rubber grommet that the petcock fits into up into the bottom of the plastic fuel tank, and the petcock itself. What year is this? I could find no model or s/n registry here. Plus I need to know where some wires go, 2 rectangular female plastic ends and a single round (for a bolt or screw) end and how and where to hook the throttle up. He had a stroke and before that had the Kohler motor rebuilt, re installed it and fell ill and has forgotten how the rest went together. He is also not online anymore.
Edited by slapshot
mispell
gwest_ca
Welcome to the forum. Thanks for helping your friend.
1977 is the model year. Click on the pictures
Garry
The Tuul Crib
:text-welcomeconfetti:to the :wh: :rs:
forum !!! I do have an extra gromet if you need one. Pm  me and let me know !!
slapshot
Thanks so much, guys! I was able to print off a wiring diagram which will help a lot! I guess I'm not sure how to PM someone? I could use the grommet!
JCM
WELCOME TO REDSQUARE         To  send a PM click on the small envelope top right hand corner pretty much self explanatory from there.
Burkee welding
Hey there I'm on the search for the fuel tank grommet also I have found similar ones on Amazon but I have not had a chance to measure the hole in the fuel tank and the Barb on the petcock but here is a part number and description for Amazon to help get you started. I do a lot of copy and paste and have found a handful of different sizes
Amazon
Fuel tank bushing # 735-0149 935-0149
Retired Wrencher
Slapshot   :WRS: There is always help here. I hope you can fix the tractor for your friend. Hope he gets better soon.
slapshot
Sorry! Nowhere on my screen do I see a "small envelope" in the upper right hand corner...
pfrederi
Circled in yellow
slapshot
Well, the fuel petcock and rubber tank grommet came in from "Wheel Horse Stables" in Harrodsburg, KY. Good service, the parts look good. We'll see if they're the right size the next time I go to work on the horse...
BOB ELLISON
Welcome to Redsquare
Here is a post that @953 nut did to help with the wiring problems.
And welcome to another michigander.
Edited by BOB ELLISON
