Similar Content
By Doodad
Well, I guess I've gone too far this time. I've got what I believe to be a 1974 Wheel Horse C-120 (12 HP Kohler serial7326629) that has performed nicely so far but looked a bit dirty so I had the great idea of cleanin' her up a little. Washed the tractor but the engine was dirty and I thought it would be nice to clean that up too so I sprayed some orange citrus cleaner on it and hosed it off and boy it cleaned right up and looks great...the only problem is, now it won't start...just grinds when I key the switch. I'm getting ready to take the hood off and check for spark but I'm suspicioning it's probably sucked water into the carb when I tried to pull it into the shop after washing. Anyway, that's my starting point but, before I go to far, I wanted to see what the Wizards of Wrenches have to say about what's wrong. I did get it to backfire and consider that an improvement but, no-starty, me no smarty. From the Doodad
By TailGate18
Need help please
Can't exactly identify my wheelhorse. I believe I've pinned it between 74-79 but not sure exactly. I'm not real knowledged in mowers but interested in learning. It ran few years ago. Then parked in a storage unit for about 3 years with gas left in it. I can't get it to run at all unless using ether.
I've drained all the old gas, I've replaced the fuel lines, new plug, new gas, but it just won't start up and keep going. I figured on new carb but don't know exactly what I'm looking for and thought I'd better know the exact details of the mower so I know I get the right parts. Any help would be appreciated. The info I do have is as follows.
The mower itself all I could find was one tag on the frame under the gas tank.
ID # 61-08K801-05782
Then under that 4 digits
6337
Has a Kohler motor info as follows
Model-K181
Spec- 30538
Displ (cc)- 305
Serial #- 2613800539
It'll crank but not start. Not even attempt to start. With the fuel line off of the fuel pump it shows it pumps fuel. I thought the possibility of the float being stuck in the bowl but again not very knowledged in this field. Would appreciate any insight, details, knowledge, help or anything of the sort. Or info on the information of the tractor so I know exactly what I'm asking questions about
Says it's a B-80 8 speed
Thanks in advance
By Chuck14025
12.6 volts in the battery and at the starter connection.
10 volts on the gauge.
Nothing when key is turned on.
By Jpud
I have I believe is a 73 commando 800 8hp kohler k181s put a new switch on it due to starter sticking on and got a new starter and completely charged the battery and new solenoid has power to the battery side of solenoid but not starter side but will turn over if jumped has no power going to the switch. Wondering if anyone had this problem before
By lodestonefarm
I went out to use my 520H with blower this evening and it won't start. I used this machine a few days ago (for the first time this winter). The battery has been on a trickle charge so I don't think that's the problem. It's done this before where it won't start, won't start, and then starts. Usually that is in cold weather and after I've previously used it to blow snow. I don't have a heated garage so I think it might have some ice somewhere that was introduced as water the last time I blew snow.
Here's what it's currently doing. When I turn the Ignition to 'On' the red warning lights and the dashs light all come on. When I turn the key to start position I get a single 'Click' and nothing more. I tried jumping it from a hot battery just to rule out a bad battery. Same behavior. Following some of the other threads about 520s with trouble starting, I pulled the blue wire off the starter solenoid. If I run a jumper wire from the (+) side of the battery directly to the solenoid I get the same behavior (regardless of key being in on or off position)- small spark where my jumper wire is touching the battery terminal and a single click.
I'm unsure what this means about the solenoid and if that, in any way tests, the starter. Could it be that my starter is bad/frozen? I tried using a heat lamp to warm up that area, but in this weather (and my garage, which is really just a tarp shed) that just isn't going to work.
I've downloaded the demystification guide and started looking at it but I'm hoping someone might have some suggestions. Snow is falling and I'm not making much headway on this.
Thanks
