richmondred01 2,318 #1 Posted June 23, 2019 Does anyone know If the correct drive belt for the 520-8 #107939 toro 93-9809 83.5”.? My clutch pedal has been jumping with toro 114895 belt which is 82.95. If believe the 1/2 is causing the jump however, the 520-8 is a unicorn and I’ve only been able to find one source saying it should be 83.5. All others list the 520-8 and 520-h as the same belt at 82.5” The numbers on my original belt are worn off. Thanks. Share this post Link to post Share on other sites
daveoman1966 3,880 #2 Posted June 23, 2019 114895 is the OEM belt at 83" length. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,844 #3 Posted June 23, 2019 Another situation where the online parts lists are confusing. There are 2 drive belts listed for item # 6 but fails to identify what models use what belt. https://www.partstree.com/parts/toro/mowers-lawn-garden-tractor/41-20o801-520-8-toro-520-8-garden-tractor-1990/drive-belt-and-pulleys/ 114895 fits the hydro models with twin cylinder engines Transmission drive belt 112801 replaced by 114895 - (HB x 82.95 or 5/8" x 82.95") 107939 replaced by 93-9809 fits 8-Speed models with twin cylinder engines Transmission drive belt 107939 replaced by 93-9809 - (HB x 83.5" or 5/8" x 83-1/2") BUT some models had a problem with clearance at the clutch damper so they came up with a 79-2500 belt 1/2" shorter and still available from Toro Click on the fuzzy picture and again on the next page Garry Share this post Link to post Share on other sites
richmondred01 2,318 #4 Posted June 26, 2019 114895 is not the correct belt. I put a new one on and I have no clutch play. Maybe 1/4 inch. Im going to try Transmission drive belt 107939 replaced by 93-9809 - (HB x 83.5" or 5/8" x 83-1/2") Share this post Link to post Share on other sites
ericj 1,579 #5 Posted June 27, 2019 I believe it uses the same belt as the 416-8, not sure what the number is eric j Share this post Link to post Share on other sites
richmondred01 2,318 #6 Posted July 1, 2019 I installed the 93-9809 belt today. It works perfect. Therefore, the mystery is solved the 520-8 uses the 93-9809 drive belt. 107939 replaced by 93-9809 - (HB x 83.5" or 5/8" x 83-1/2") 1 Share this post Link to post Share on other sites
