Pat Marchwick
Hydraulic help
Pat Marchwick
Is there a hydraulic Trouble shooting chart anywhere for wheelhorse hydrostatic and hydraulic system ?
such as :
           Problem        Possible cause
tractor climbs slope fine in reverse but not in forward, .        Bad spool valve ?
tractor does not move.                                                            Low fluid, plugged fIlter ?
lift cylinder works but tractor will not move.                              Bad shift linkage!  Internal oil leak in valve?
looking for help figuring out my tractor weird behavoir
to go forward up a 15 degree incline I have to find a sweet spot with the directional handle. Too far it won't climb and irs not a lack of power. On level ground it works ok.
thank you
bc.gold
such as :
thank you
From what your describing sounds like you have weak or broken spring the charts below are from the Sundstrand used in Allis and Simplicity. But the acceleration valve is a common component on all hydro units.
Edited by bcgold
daveoman1966
What tractor...  Sundstrand or Eaton ???
bc.gold
You mean this one.
eaton.pdf
Edited by bcgold
