tommyg
Clutch Brake repair
tommyg
I've got the rivets showing through on the clutch brake for my d-180. Toro says the part is NLA. I'm sure this has been discussed before, but how can I replace the friction material so I don't damage anything since I now have metal touching metal? Doesn't seem like rocket science, but I'm not sure where to start.
The Tuul Crib
Theres a way to glue it . @WHEELHORSEFAN*16 just did one
said it turned outgreat!!
Pollack Pete
I know OSHA wouldn't approve,but whenever I have one worn down to the rivets,I take it off and toss it in the scrap metal can.I'm the only operator here and I know enough not to get off the tractor and stick any part of my body where they don't belong.Plus,I'm old and slow and everything is usually done spinning by the time I get off the tractor.
Edited by Pollack Pete
Guest 88vic
I got a new brake band lining from Robert Maynard who frequents on here alot. I went to his ebay page and ordered one. It came quickly. I took the band off, removed what was left of the liner material, wire wheeled the brake band down to bare metal on the inside. Instructions say to use zip ties or rubber bands, i used a small coffee can to wrap it around and pulled it tight. I used Goop brand all purpose adhesive and went in a "s" pattern with the glue. I let it set untouched for a full 2 days. It probably wouldve been fine overnight but I was busy with the family. I reinstalled it, adjusted to my satisfaction and works great !
WHX??
Glad to hear it worked out Fan.....Bob's dam near a founding member and all around good guy.
Guest 88vic
I never knew that !  I look forward to meeting all of you at the show this Friday. Itll be nice putting names to faces 🤓
tommyg
Guys, this is just a very small “L” shaped bracket with a piece of braking material maybe an inch and a half in length and a half inch in width riveted to the outer edge. It presses up against the inside of the PTO pulley when the clutch is released to stop the spinning pulley. (and subsequently, the mower blades or snowblower auger. Gluing a new piece on makes sense. But where does one purchase a flat piece of braking material like this?
pfrederi
https://www.mcmaster.com/brake-lining
Tommy i found I had a piece.  it is 2" wide and 1/4" thick.  How long a piece would you need i can cut it off and send it to you
Edited by pfrederi
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      Finally getting around to working on my ark loader.  The previous owner said he thinks the problem is with the spool valve.
      As I've learned a bit more about hydraulics now, I'd like to get this all sorted out.
      I noticed the power beyond port is connected to the reservoir return.  Is that right?
      Anyone see anything blatantly incorrect?
    • ccs002
      By ccs002
      Looking for a complete hydro pump for a D-160. Tractor is missing everything from the rubber coupler disc back. Also willing to buy a complete tractor for parts, the closer to Harrisonburg VA the better. Thank you.
    • tractorboy79
      By tractorboy79
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
