bc.gold
30 seconed delay
bc.gold
Summer is here the thieves have to much time on their hands.
Going to install an alarm system, air horn from an old Mack truck, air solenoid from a dump find that had many of these that I removed and finally found a use for one.
The occupancy switch mainly used to turn lights on and off but also is capable of handling small loads, I'm going to set the switch to turn on after a 30 second delay give the little buggers plenty of time to make a full entry into the shop and hopefully close the door behind themselves to avoid detection.
The 30 second delay also gives me time to turn the power off before the horn blows.
Maybe even invite the bear into the shop for its maiden run.
Edited by bcgold
formariz
Better have hearing protection just in case. That horn inside a structure will make you deaf in 30 seconds.
ol550
A farmer I used to do work for had his shop about a half mile from his house. Had one horn on top aimed toward his house and several inside. Only took once and no more theft problems for years.:lol:
