canam1991
D-250 rear end
canam1991
Whats an oil to put in it original 80w-90, 10w-40,10w30? I've heard mobile1?
clintonnut
We used synthetic 80w-90 or 75w-90 works too. It costs about $10 a quart and you need 8 quarts. It will last forever.
Charlie
canam1991
i holds 8 i was told around 6?
clintonnut
Maybe it is 6.
Charlie
canam1991
IS 10w-40 to thin? i heard of guys using mobile 1 synthetic 10w-40 to cut down wear on the worm gear?
canam1991
:omg:
Dual Wheels
5. The transaxle fluid capacity is 5.5 qts. (5.25 liters).
Using a pump gun, fill the transaxle to the full mark on
the dipstick with SAE 90/Hypoid fluid.
Strait out of the repair manual
canam1991
So i saw in my manual but i was wondering if anyone has had luck with different weight oils because i have 6 quarts of 10w40 laying around but do you think it is to thin? :omg:
iicap
10W-40 is motor oil and not designed to do the job of a gear lubricant in an application like this. There are situations where a SAE 50 motor oil is used in heavy duty truck transmissions as per the trans manufacturer saying it can be used instead of their preferred lubricant. I say this just to let you know that sometimes there are alternatives.
ALWAYS use the recommended lube in gear cases and you won't go wrong. There are times when newer lubes come out years later that may serve better. Synthetic lubes such as 75W-90, 80W-90, and 85W-140, and some that are not synthetic can/could be used instead of Hypoid-90.
Fair warning, materials of a lot of older seals have been found to fail with the use of synthetics. Also I believe a member of RS is in the lubricant business and I think he could correct anything I may have mis-stated and he also could speak authoratively about this subject
