boondockboost 34 #1 Posted June 14, 2019 I dug my raider 12 outta the weeds today and got her running again after about 2 years. I was mowing the yard with it and I broke the tensioner pulley for the blades. I was searching around and couldnt find a match so I figured id ask. Its a 36in side discharge deck. The pullley seems to be 3/8 mounting hole 3 -3/4 tall 3/4 inside belt dia. (The center bearing is not in the pulley) Share this post Link to post Share on other sites
daveoman1966 3,788 #2 Posted June 14, 2019 (edited) That is actually a 42" side disch deck.... I edited this post...had wrong idea of what you needed... as per heads up from Garry. Edited June 14, 2019 by daveoman1966 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,206 #3 Posted June 14, 2019 Dave I think he needs the flat idler on the deck. Might be this one Flat idler pulley - 3.750" OD - 3-3/4" - WH 6719, 112425, 519567 replaced by 92-7101 Napa 7-05207 with flanges, Stens 280-099 Std Flat OD 3.250", Stens 280-578 replaced by 280-114 HD Flat OD 3.250" No picture Garry Share this post Link to post Share on other sites
boondockboost 34 #4 Posted June 22, 2019 Well the pulley nunbers you have worked great everything is back together . only issuse know is I noticed the pulley for the blade seems to be rotting out. Is this a common oulkey to find? Or is it gunna be a treasure hunt? Share this post Link to post Share on other sites
