Firebug
Trans oil fill tube
Firebug
I just found this on my 310-8. Just curious how the tube goes into the transmission. Is the plastic tube threaded in or pressed in. Snapped off pretty flush with the casting. Any thoughts how to get it out without dumping a bunch of junk in there and where would I source a replacement
ol550
Screwed in.
1995 520H+96+97
Screwed in. Take a chisel that will slide into the broken piece, tap with a hammer, and turn it out with a wrench on the chisel. Some on e bay or new at Partstree, or Toro.:wh:
Edited by 1995 520H+96+97
The Tuul Crib
Aren’t these made from plastic?
Firebug
Yes it is plastic. But it’s pretty protected on there. Doesn’t look like it’s available on parts tree so eBay it is. Does that need a thread seal tape around it or is it ok to just screw it in without
The Tuul Crib
Teflon tape would help ease it in . I wouldn’t over tighten it tho. Maybe hand tight then another half or so turn with a wrench.
Firebug
That would be something I do, snap the new one off
daveoman1966
How long is that filler tube?   I have several here to suit....  $15 shipped to you in USA.
Firebug
I will measure it, that’s the same price as eBay but at least I’ll know what I’m getting
daveoman1966
The filler tube I have is 8" long...including threads.  One of the 4 corners of the 'square' is broken off, but the tube isn't cracked and the threads are all good to go.
Firebug
That looks like it, mine is 7 1/4 including the flats but not the threads. They are hard to measure stuck inside the transmission
daveoman1966
I'm thinkin' the tube I have will suit your needs.  The one I have is just 7" long to the SQUARE of the tube....  just above the threads.
Put $15 to my Paypal account...as SEND MONEY TO A FRIEND.....
My account name is:   daveoman@windstream.net.
Be sure your mailing address is noted in the payment you send.,
