12 hp Kohler 1,014 #1 Posted June 14, 2019 Mods, if this is in the wrong place feel free to move it. I am looking for a parts manual and wiring diagram for my electro 12. Can’t seem to find one in the manuals section but I might just be over looking it. Also if anyone knows what ignition switch I need that would be great too. It has the points and coil ignition but it has the incorrect ignition switch on it now. Thanks in advance. Share this post Link to post Share on other sites
ZXT 2,401 #2 Posted June 14, 2019 2 hours ago, 12 hp Kohler said: Mods, if this is in the wrong place feel free to move it. I am looking for a parts manual and wiring diagram for my electro 12. Can’t seem to find one in the manuals section but I might just be over looking it. Also if anyone knows what ignition switch I need that would be great too. It has the points and coil ignition but it has the incorrect ignition switch on it now. Thanks in advance. Here's a simplified wiring diagram, provided to me by Richard (953 nut). The switch you want is 103 990. 3 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,190 #3 Posted June 14, 2019 Can you post the tractor model number and serial number? Also the engine spec number off the decal. There were 3 different ignition systems used at the time and you don't want to mix the parts up. Gets real expensive to fix. Garry 1 Share this post Link to post Share on other sites
12 hp Kohler 1,014 #4 Posted June 14, 2019 3 hours ago, gwest_ca said: Can you post the tractor model number and serial number? Also the engine spec number off the decal. There were 3 different ignition systems used at the time and you don't want to mix the parts up. Gets real expensive to fix. Garry Here is the tractor model and serial number. Don’t have a picture of the engine spec number, I will try and get one soon. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,190 #5 Posted June 14, 2019 1970 Electro 12 model 1-7255 - Uses Kohler K301S-47371c This one uses magneto ignition. Click on the fuzzy pictures Do not have a wiring diagram but the wiring for the 1970 Raider 12 is the same because they used the same engine spec. Only difference will be additional wiring if you have an electric pto clutch. Garry 1 Share this post Link to post Share on other sites
12 hp Kohler 1,014 #6 Posted June 14, 2019 6 minutes ago, gwest_ca said: 1970 Electro 12 model 1-7255 - Uses Kohler K301S-47371c This one uses magneto ignition. It may have had a magneto from the factory but someone must have switched it at some point. Currently it has breaker points and an almost new coil and plug wire. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,190 #7 Posted June 15, 2019 Sounds like you now have battery ignition so use what ZXT posted above and the 103990 ignition switch. Click on the picture for more Garry 2 Share this post Link to post Share on other sites
12 hp Kohler 1,014 #8 Posted June 15, 2019 Awesome thanks. At the moment the tractor doesn’t have a solenoid on it but when I re wire it and put a new ignition switch in I will put a solenoid on. 2 Share this post Link to post Share on other sites
