JoeA
Drive belt question
JoeA
I have the parts manual for a 417-a   says the drive belt part number is 7466.
Is there a newer number for the drive belt ?
Edited by JoeA
Bad data in question
Skipper
7466 is the drive belt pulley on the engine if I'm not mistaken.
108501 would be the belt number If I read the chard right.
That is a 81" B belt. Also known as B78K.
You can pick those up for about 10-15$. I would recommend the blue stuff from TSC and others.
  • Like 4
JoeA
Duuuuh  Yes u are correct  That explains why I could not find a belt that does not exist.....  Looks like tractor supply TSC right down the road has a 5/8 X 81 Kevlar belt
Thank you for the clarification..... Need to look closer at the part description next time
  • Like 3
peter lena
having a t/s close by makes a belt match easy , lucky you, pete
