JaysHorse
Snow blower auger
JaysHorse
I need some help. My sprocket on my single stage blower went to hell on me. I was wondering if anyone knew if the auger from a unit for 260 is the same as mine for my 518? Or is there any other way to repair my existing one. Thanks
gwest_ca
Some are the same.
Can you get the model numbers and serial numbers of both units? With those we could compare the parts lists.
A worn out chain is the biggest cause of sprocket failure.
Garry
JaysHorse
79263 sn 200000354
79360 sn 7900001
JaysHorse
After a little research I’m guessing it’s the same. My part is 105-1478 which replaced 93-1615-01 which is what’s called for for the thrower for 260. Anyone ever try just replacing the sprocket on the auger?
JaysHorse
Before and after shot. New sprocket picked up from TSC.
peter lena
nice fix on that, using a 36 - 42  single stage now for years , i would say that  LUBRIPLATE  CHAIN AND OPEN GEAR SPRAY IS THE BEST OPEN GEAR LUBRICANT YOU CAN USE ON A BLOWER. my unit spins up with total ease by hand, i never let the gears or chain dry out, i also spray it down after use. i also detailed the idler pulley frame on this , totally eliminating any rusty contact points. btw, if you want to take out any impact points on the auger , use  2  large crescent wrenches in oposit  directions on the auger area, makes the repair very easy. pay attention to the chain adjustment point, i use crescent serated washers to hold the setting , they bite into the area. good luck with that , pete
JaysHorse
Thanks for the lubing tip Pete. I think while I got it this far down I’m going the distance and will be sanding and repainting to get another 30yrs out of it
rjg854
not a bad idea at all , and just remember :wwp:
JaysHorse
Starts in 2 weeks. Stay tuned........
gwest_ca
On 6/7/2019 at 1:13 PM, JaysHorse said:
79360 sn 7900001
Do you realize that is the very first serial number issued for 1997?
Garry
JaysHorse
No I didn’t. That make it worth more?
bc.gold
It does not look like the teeth on the replacement gear have been hardened nor do we know if the gear is made from a material that is capable of being heat treated.
Put a file to a tooth to the check hardness, below is an example of an induction hardening you can also flame harden by quenching.
JaysHorse
Thanks for the tip. I will give it a try. Also anybody know how to remove the bearing from the end plates without harming them? They are in great shape.
bc.gold
The shaft needs to be pressed out - hydraulic bench press. There's also a split bearing puller threaded for a puller.
Be sure to report the file test.
JaysHorse
Well I put the file to it. Scratched it a little but not much more then that. Did the same effect on the original gear.
JaysHorse
Ideas on getting these off?
bc.gold
Those collars just slide onto the shaft it's the set screws that have made a burr on the shaft, once you get past the burr your home free. In the old days to remove a tie rod used a heavy hammer on one side the used another hammer to give to opposing side a good whack.
Those collars are cheap to replace, any farm supply or bearing house will have them in stock.
The civilized way is to use a pickle fork, you might try a wedge.
Edited by bcgold
JaysHorse
I have one of them. I will give it a try. I get it to move except where there is a partial drilled hole next to set screw.
gwest_ca
When installing the collar you place it in position and use a hammer and punch in that blind hole to turn the collar in the direction of rotation when the unit is operating. The cam will lock the inner race of the bearing to the shaft so the shaft won't spin in the bearing.
So tap it in the opposite direction to release it.
Make sense?
Notice how the hole in the bearing appears to be not centered? The collar is the same and that eccentric is what locks the bearing.
Think of it as a circular wedge.
Garry
  • Thanks 2
JaysHorse
Making progress on the restoration.
JaysHorse
Getting closer.
jay bee
Looking good!!!
JaysHorse
Nice and shiny. Next project........
