CountryRock
Push mower carb help
CountryRock
I'm working on a mid 90s Craftsman push mower with a 6.5hp Briggs Quantum engine.  Is has a non-adjustable LMS type carburetor on it.  It ran a little rough, so I took the carb apart, cleaned it and rebuilt it.  Everything got blasted with carb cleaner and air when it was apart.  I put it all back together and now it won't run unless I squirt gas into the intake.  Bowl has gas in it.  What am I missing?
Guest 88vic
Get a new carb on ebay or Amazon, they are only about $15.   Throw it on and forget about it.  If not, the main jet in carb still needs cleaned out, also the little nut that holds the bowl on has small holes, those may be plugged up as well. Make sure the carb vents are clean too.
CountryRock
The bowl nut is the main jet and it's clean.
JoeM
You have to stick small wires, like a torch tip cleaner, tag wire, or even a stripped bread tie up through those main jet holes. I have done the same in the past with cleaner and air but had to loosen crud with a wire to get the best effect. Ethanol Pearls!
CountryRock
I did all that.  They are all clean.
WHNJ701
turn the fuel shut off to the on position
tunahead72
Did you replace the fuel line?  Check the tank outlet?  Will it keep running after you spray gas into the intake, or does it die?
Guest 88vic
Did you take the welch plug out of the carb ?  Ethanol pearls like to plug up that passage way.
CountryRock
Ok.  Here's an update.  Fuel lines are new, fuel valve is on.  I took the carb back apart and blasted everything again.  Put it back together, new primer, new gov spring.  The carb primes fine.  Plug is wet, I dried it.  There is spark.  I have no idea why it won't pop.  I did try starting it without the blade earlier in the week, it was hard as hell to pull.  Could there possibly be a partially sheared flywheel key?  It only fires if I squirt fuel way into the intake and then only runs a few seconds and dies.
Edited by CountryRock
WHNJ701
yes check the flywheel key.  I had a cracked key on a horizontal, sometimes it ran sometimes it didn't. it had a hairline crack, changed it and it was fine.
recently I picked a free snapper hi vac with a briggs, same thing it run on fluid, it was missing the the rubber breather hose, 4 dollars later I have a good running push mower
check your kill switch wire make sure it's not grounding out
CountryRock
I took the top cover off and took the flywheel nut off.  The key doesn't look sheared at all.  I have a puller and keys coming, but now I'm not sure that that is the issue.  I am absolutely stumped on this engine. :ranting::ranting:
CountryRock
Ended up getting a cheap china carb for it.  Works fine now.
