steelman
Tiller spring
steelman
I picked up a model 7-1251 tiller yesterday. I wasn't able to find this model in the manual section, but there is a 7-1252 manual, which is probably a year or so older. It is complete with exception of the idler spring. Can someone give me an ideal of what spring will work? Maybe its not that critical but I want to mount this on a C100 for now but hope to eventually mount it on a C160, both mid 70's tractors.
steelman
I have the lift assist spring that I use for the snowblower. This is a smaller spring that goes from the frame to the front idler assembly.
lynnmor
That is the lift assist spring, apparently he needs the much smaller spring for the pulley.
My spring is 3-1/2" overall length, 5/8" diameter and is made from .073" wire.  You should be able to find something at a good hardware store.
steelman
That helps me out...thanks!
