Tractorman1 1 #1 Posted June 5, 2019 I am looking to purchase a snow plow for my wheel horse 310-8 and have found a 54" blade at a fair price and wanted to know if this size would fit my tractor or do I need to find a smaller size? Share this post Link to post Share on other sites
ebinmaine 70,298 #2 Posted June 5, 2019 2 minutes ago, Tractorman1 said: I am looking to purchase a snow plow for my wheel horse 310-8 and have found a 54" blade at a fair price and wanted to know if this size would fit my tractor or do I need to find a smaller size? That's allot of blade to push with a 10 horse. Most of us prefer a 42 or 48. It's more about having enough weight though. My plow tractor is well over 900 pounds. 4 Share this post Link to post Share on other sites
JoeM 7,904 #3 Posted June 5, 2019 I use a 48m but I have used a taller 42. The 42 worked better on deeper snow, but the 48 works good and when angled it clears a path about the same as the 42 in the straight position. As EB said, 54 is pretty wide and weight makes the difference, traction is key. 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,206 #4 Posted June 5, 2019 If you find the 54" is too big I am sure someone with a larger tractor would swap with you. Garry 5 1 Share this post Link to post Share on other sites
Ed Kennell 40,188 #5 Posted June 5, 2019 I have a 42" that I would swap for a 54". I am looking for a 54" for my 520H. 1 Share this post Link to post Share on other sites
wallfish 17,383 #6 Posted June 5, 2019 49 minutes ago, Ed Kennell said: I have a 42" that I would swap for a 54". I am looking for a 54" for my 520H. Sawzall, 2 blades and a welder can make any size you want. I was pushing a 60" blade with the backhoe tractor with Ag tires only and didn't have issues but of coarse there is a ton of weight on that tractor. Only issue was shear ice but turfs with chains would've easily cured that. @ebinmaine has it now so I guess we'll see what he comes up with to push it. Traction is the only thing you need for a large blade. An 8hp would be enough power with a manual trans. Probably a hydro too but I never had an 8hp hydro. 1 2 Share this post Link to post Share on other sites
ebinmaine 70,298 #7 Posted June 5, 2019 1 hour ago, wallfish said: @ebinmaine has it now so I guess we'll see what he comes up with to push it. My cinnamon horse c-160 has 23 x 10.50 rear tires and some oversized 20 by 8 by 8 on the front. All four are fluid filled with beet juice. I have 255 lb of liquid weight alone and then another 100 in steel. There's also over 250 lb of... Me. I also have ice cleats chains for the rear. We've gotten into the habit of removing most of the depth of the snow with the commercial walk-behind snowblower then scraping the yard with the plows. I'm nowhere near even remotely close to getting anxious about having snow again but I have to admit I am looking forward to seeing what that super plow will do. 1 Share this post Link to post Share on other sites
Ed Kennell 40,188 #8 Posted June 5, 2019 we got weight. 2 Share this post Link to post Share on other sites
