Shea Worden
8 speed transmission problem
Shea Worden
Hey guys, my wheelhorse c81 got a new transmission last year and now it’s grinding when I drive. First thing the brake pulley is on a higher shaft and doesn’t work with the c81 brake rod and hardware. Second the bearing behind the intake pulleyhas fallen out, which I assume is the grinding sound. Is there a way I can fix it without taking the whole transmission apart? I don’t have enough knowledge to do that kind of repair. Thanks so much -Shea
Achto
A couple of pictures may help us better understand the extent of the repair needed. If you do need to take the tranny apart @stevasaurus has some great video's to walk you through the process.
stevasaurus
Shea, you will have to open the transmission to fix the bearing...and I would not drive it around anymore until that is fixed.
We need a couple  of pictures of the trans to see what it is.  A good picture of the left side showing the brake drum and axle, and one of the right side with the input pulley and the top of the trans.  Do you know the story behind the transmission.??
   Shea, if you know how to use a 9/16 box end wrench, you can do this trans.  :occasion-xmas:
ebinmaine
If you need any pictures of what that thing is supposed to look like let me know. I have a C81 Parts tractor.
Steve is right. Repairing your transmission may seem a bit daunting but it's actually a pretty simple setup. Any kind of minor mechanical knowledge at all and you will be able to handle that repair.
The fine folks on Redsquare will be more than happy to help you out from start to finish.
Shea Worden
The first photo is the side opposite the brake shaft, as you can see there is no bearing so it rattles back and forth and grinds. The others are my original and new transmission on the bench, then I cracked open the original transmission. Where can I find gaskets, seals , and bearings for these?? Thanks for all the help so far guys
dcrage
I don’t know transmissions. BUT I do know from reading this forum that you want to have the shallow side DOWN before separating the case.
Shea Worden
Well I guess I’m going to have a little mess trying to do that 😂
ebinmaine
You go in the vendors section and look for Wheel Horse parts and more. Lowell will set you right up with every single thing you need.
The Tuul Crib
:text-yeahthat:
Shea Worden
Thank you very much I’ll go check him out right now 👍👍👍👍👍👍👍👍👍
The Tuul Crib
All the oil seals you can get from you local
napa auto parts.
stevasaurus
Shea, here is the manual for taking apart and putting together that trans.  You want section V.  I also have some videos in the reference section/transmissions that may help you.  You would want the one that deals with the #5060...while not your trans, it is very similar.  :occasion-xmas:
You may have to turn that trans over to get it aart...I believe the 1st thing after the bolts is the hi/low lever and your shifter...and all pulleys and hubs.
  • Similar Content
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
    • davidfindlay
      By davidfindlay
      Looking to find a new home for my 84 (I think) C-145. It has a dump trailer with the enclosure for leaves, the PTO impeller to get the leafs into the trailer, the hoses for deck-to-impeller, impeller-to-trailer.
      I haven’t run it in over a year.
      The battery and the cable to the battery probably need to be replaced.
      Comes with a new head gasket still in the bag.
      Seat is cracked but still comfortable.
      Happy to answer questions or take other pictures.
    • Rob R
      By Rob R
      Hi Guys my C81 has a 38 dual blade, side discharge mower deck (# 0537SC01) The deck belt also goes around the mandrels through the mule drive and also to the PTO so it's a huge belt. The current belt is stretched and ready to go. I believe it is around 1/2 X 142 inches but not sure was hoping one of you might have the correct size. Much appreciated. Rob
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
      1984 C-105 8-Speed model 11-10K802
      1984 C-125 8-Speed model 11-12K802
      1984 C-145 Automatic model 11-14KE01 - Some used alternate inner axle bearing See PSB #369
      1984 C-165 8-Speed model 11-16K801
      1984 C-175 Twin Automatic model 11-17KE01 - Some used alternate inner axle bearing See PSB #369
      1984 C-195 Twin Automatic model 01-19KE02
