wshall2
TORO Mower Deck questiosn
wshall2
Hi, I recently purchased a garden tractor and it came with a TORO mower deck (although it is a different brand ) the mower deck was never used on this tractor and possibly  (based on look of the underside ) never used ever.  Before I attempt to modify it to work on my tractor, I thought it may be worth finding out if it was of any value to wheelhorse owners looking for an original deck?  On the tag on the top (which is very faded ) I did make out the TORO name, but stopped looking further, let me know if you need me to see if I can get more numbers off of it to help identify it and its value/interest?
  • Excellent 1
71_Bronco
I would personally not modify it.
Not sure what the value would be, as they vary quite a bit (depending on condition, age, models it fits, etc). I am not an expert on this style deck.
What model tractor did it come with?
WVHillbilly520H
Looks to be for the xi series...44"?
clueless
Looks like it still has the model and serial number on it. Give us those and Garry will figure it out :rolleyes:.
wshall2
It came with a case tractor I just bought, PO picked it up years back to put on that case tractor but never touched it, not sure the original one it came with
wshall2
I will inspect the tag again tomorrow, was very faded
wshall2
4 hours ago, gwest_ca said:
Will guess it is a 48" width of cut model 78363 so one of these
https://www.wheelhorseforum.com/search/?&q=78363&type=downloads_file&search_and_or=or&sortby=relevancy
Garry
Gary, I think you may be right on the model, I just went out and as can be seen from this picture, the model number is partially damaged on the tag, but I can make out "363" and what looks like an "8" in front of that, and it does measure 48" wide, each blade is 16".
That being found, what mower would this have been for, and is there any interest in it?  What would it potentially be worth?  Still trying to determine if I modify it to fit my tractor, or sell it and try to find the correct deck for my tractor.
Thanks
WVHillbilly520H
18 minutes ago, wshall2 said:
Gary, I think you may be right on the model, I just went out and as can be seen from this picture, the model number is partially damaged on the tag, but I can make out "363" and what looks like an "8" in front of that, and it does measure 48" wide, each blade is 16".  imageproxy.php?img=&key=233175c88be08e9b
Thanks
Xi series attachments are not as easy for us :wh: to find...i recommend you list in the classifieds and start looking for a deck to fit your CASE...JMHO...
gwest_ca
The 78363 serial number will be 8902081 making it a 1998 model. Pretty important that you don't loose those numbers.
Garry
wshall2
Garry
Thanks for the info.
Only had it for less than a week and just looked at the tag for the first time today, got a picture so even if the tag gets worse, I have that.
23 Reo
You have a really nice deck. I would sell it  for $350 to $400 and use the money toward the purchase of the correct deck for your Case.
doc724
It is definitely a deck for an xi tractor.  It looks to be in pretty pristine shape on the underside but it was outside for a long time as witnessed by the faded paint topside.  Depending on local demand, you could easily get $350-400 as suggested by 23 Reo
wshall2
Thanks for the tips guys, I appreciate it!
