Ed Kennell 40,360 #326 Posted June 6, 2019 Check with Bob Maynard in the vendors section. Share this post Link to post Share on other sites
VinsRJ 723 #327 Posted June 6, 2019 (edited) Hello, looking to sell the following, Best way to reach me through PM 416 Kohler single muffler, will fit other big bock single Kohler engines, very good condition with no rot, heat shield included … $70 Kohler twin (KT/Magnum) heat shield with bracket and hardware… $40 (SOLD) 12x8.5 rear rims, rims are specifically off a JD, rear lip to mounting surface (as would be mounted on a WH) back spacing 4”, front lip to mounting flange 4.5”, these were super clean rime when I had them gloss black powder coated, no rust pits, no dings, no dents, a little wear in the powder coat where the lug nut rubbed the rim, I ran these on my 857 with .25” spacers and a 23x10.5x12 tire without issue, I will include the spacers… $100 Thank you, Vin Edited June 7, 2019 by VinsRJ Share this post Link to post Share on other sites
Ed Kennell 40,360 #328 Posted June 6, 2019 Onan intake and carb. $35 Share this post Link to post Share on other sites
953 nut 57,690 #329 Posted June 6, 2019 On 6/6/2019 at 3:39 PM, VinsRJ said: Kohler twin (KT/Magnum) heat shield with bracket and hardware… $40 PM Sent. Share this post Link to post Share on other sites
Buzz 502 #330 Posted June 7, 2019 (edited) SOLD Cute little cart. NOT WHEEL HORSE but can be towed behind one. Will bring to show if paid for in advance. $35.00 Edited June 9, 2019 by Buzz 4 Share this post Link to post Share on other sites
Buzz 502 #331 Posted June 7, 2019 (edited) SOLD C-160. Runs and drives good. No smoke or knocks. Hydraulic hoses leak and need to be replaced. Will bring to the Show if paid for in advance. $300.00 Edited June 15, 2019 by Buzz 2 Share this post Link to post Share on other sites
roadapples 6,983 #332 Posted June 7, 2019 Short frame snow blade with axle bracket, $100. Will through in mower deck. Has been patched but still mowes. Can't do pictures. Look me up... Jay Share this post Link to post Share on other sites
squonk 42,428 #333 Posted June 7, 2019 On 6/7/2019 at 12:08 AM, Buzz said: Cute little cart. NOT WHEEL HORSE but can be towed behind one. Will bring to show if paid for in advance. $35.00 PM sent! 1 Share this post Link to post Share on other sites
fast88pu 3,325 #334 Posted June 7, 2019 Looking for a cheap rj or suburban for lawn art. Share this post Link to post Share on other sites
Buzz 502 #335 Posted June 7, 2019 On 6/7/2019 at 6:58 PM, fast88pu said: Looking for a cheap rj or suburban for lawn art. Carol would kill me if I sold this. 2 1 4 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,397 #336 Posted June 7, 2019 Oh boy.... Share this post Link to post Share on other sites
RJ Hamner 1,025 #337 Posted June 7, 2019 Ya gotta admit that's a real classy yard ornament. 1 1 Share this post Link to post Share on other sites
BHunter 1,700 #338 Posted June 7, 2019 1978 C101 . Runs with jumper wire to coil . No smoke. Had it running with a hose in a cup of gas. Needs a fuel line back to tank. I didn’t try the trans but I changed the fluid. It has clear coat over original paint . Make offer. 1 Share this post Link to post Share on other sites
BHunter 1,700 #339 Posted June 7, 2019 1970 raider 10 . It’s been stripped down to bare metal and painted with enamel . Needs to be put back together. Motor has compression and spark. Make offer 1 Share this post Link to post Share on other sites
cafoose 3,383 #340 Posted June 7, 2019 On 6/5/2019 at 4:21 PM, cafoose said: Mounting hardware needed to mount 7-1211 tiller to my C161. I need item numbers 41 to 42, 55 to 65, and 79 to 97. I will be at the show a lot because I'm only 45 minutes away. Not sure of the exact times. If I can't find what I need to make the 7-1211 tiller work on my C161 I may consider getting an older with a gear drive tranny that I can use with my tiller at the show if anyone has any to sell cheap. Share this post Link to post Share on other sites
squonk 42,428 #341 Posted June 7, 2019 @Buzz did you see my PM about the cart? Share this post Link to post Share on other sites
fast88pu 3,325 #342 Posted June 7, 2019 On 6/7/2019 at 7:22 PM, Buzz said: Carol would kill me if I sold this. I'd buy it Share this post Link to post Share on other sites
dells68 7,498 #343 Posted June 7, 2019 (edited) Set of Wheel Horse weights, pretty nice - one is cracked on one side and the other has the usual scuffs. I only have 3 mounting bolts. $75 pair of 13x5.00-6 ag tires SOLD Mule drives with knobs (have two) $25 Muke drives without knobs (have 4) $15 GT14 dual pulley for operating a rear tone tiller $60 My 953 that I’m not 100% sure I want to sell, but could use the storage space! Just rebuilt the carb and it runs great. Just a little smoke on throttle up. The hydraulics function as they should but the spring in the pump is broken as usual. Tractor was cleaned up and painted all over with all new seals in the transmission. Sorry about the seat - my attempt at upholstery! $850 Edited June 7, 2019 by dells68 3 Share this post Link to post Share on other sites
fast88pu 3,325 #344 Posted June 7, 2019 On 6/7/2019 at 10:32 PM, dells68 said: Set of Wheel Horse weights, pretty nice - one is cracked on one side and the other has the usual scuffs. I only have 3 mounting bolts. $75 pair of 13x5.00-6 ag tires $25 Mule drives with knobs (have two) $25 Muke drives without knobs (have 4) $15 GT14 dual pulley for operating a rear tone tiller $60 My 953 that I’m not 100% sure I want to sell, but could use the storage space! Just rebuilt the carb and it runs great. Just a little smoke on throttle up. The hydraulics function as they should but the spring in the pump is broken as usual. Tractor was cleaned up and painted all over with all new seals in the transmission. Sorry about the seat - my attempt at upholstery! $850 Dibs on the ags. I'll take them. 1 Share this post Link to post Share on other sites
squonk 42,428 #345 Posted June 8, 2019 Better pis of the backrest $125.00 Share this post Link to post Share on other sites
RandyLittrell 3,894 #346 Posted June 8, 2019 @fast88pu Sorry about the seat - my attempt at upholstery! I think it looks great, I see no need to say your sorry!!! Randy 1 Share this post Link to post Share on other sites
dells68 7,498 #347 Posted June 8, 2019 Since I got the 414-8 this week, I decided to sell my low hour 1996 312-8. This is one of my the nicest 300 series tractors I’ve seen. Of the 501 hours on the clock, the previous owner estimates about 100 we a result of his grandson forgetting and leaving the key on. The only flaw is a crack in the seat cushion. It had an electric pump on it when I bought it, but I haven’t had good luck with those, so I installed a Briggs and Stratton pulse pump along with a primer bulb for cold starts. Two squeezes of the bulb, partial throttle, and a little choke and it fires right up every time. Runs smooth with no smoke or noises. I did convert the front wheels to 8” ones including the correct spindles. I do have the 6” wheels and tires if you’re interested. There is also an extra bag and upright mounts for the bagger. The battery is a little weak with around 10 volts. I charge it just a minute or two before I start and it builds back up to 12+ volts as soon as it starts - just an older weak battery. It will start every time for the rest of the day. I could replace the battery, but that would add $50 to the price. If you need a nice, almost new mower, this is it! $750 Share this post Link to post Share on other sites
dells68 7,498 #348 Posted June 8, 2019 Decided I would post a couple videos of the 953 running for you to check out. Emory had to go for a ride! 2 Share this post Link to post Share on other sites
Ed Kennell 40,360 #349 Posted June 8, 2019 (edited) On 4/19/2019 at 10:54 AM, Ed Kennell said: Engines K241A no starter or points $75 SOLD K301S no starter $100 SOLD Tecumseh starter runs OK $35 Getting close to show time.....BOGO on these engines. Both engines are SOLD. Edited June 8, 2019 by Ed Kennell Share this post Link to post Share on other sites
Ed Kennell 40,360 #350 Posted June 8, 2019 On 5/29/2019 at 11:37 PM, Ed Kennell said: 8" moldboard plow....maker unknown. $50 Reduced price to $50. It looks bad, but the rust is not real deep and would clean up with a wire wheel. 1 Share this post Link to post Share on other sites
