The Tuul Crib
What does this relay do?
The Tuul Crib
What does this relay do?  I’m just curious I’ve been running through the manuals in the files in the wiring diagrams. Can anyone tell me?
Its on my 312-8
Edited by The Tool Crib
gwest_ca
Click on the picture in the link
Garry
adsm08
It uses a low current circuit to switch a high current circuit.
Lee1977
I don't think anyone answered your question. I'm sure you know what a relay is. On the 312 it is connected to the low oil switch on the Kohler. Mine wasn't connected to anything when I got. I always check the oil be fore starting, unless I forget. I have never bothered to see if the low oil switch works.
I found the answer in the electrical layout for the 312.
Edited by Lee1977
gwest_ca
For anyone that plans to remove the low oil switch to give it the 500 hour service recommended read up on how to remove the switch without damaging it. They are no longer available.
Garry
953 nut
I have a couple of NOS Kohler oil sentry switches on :techie-ebay: if someone needs one.
clueless
Been wondering about that thing also on my 312 for a few years. Once again thank guys.
The Tuul Crib
I have one terminal on that relay
that has no wire and l have a couple of wires that need a place to go. I found the wiring diagram on the manual section and
now figured out where they go. I picked up this 312 for 100 bucks. The PO was suppose to be a small engine guy and was going to scrap it because it wouldn’t run.
It doesn’t smoke . Win!!
