clueless
37 inch bagger chute?
clueless
I've got a '88 37" two blade deck, also have the bagger chute that bolts to the deck. Looking for how it bolt up to the deck, I know it's just a couple of bolts and nut, but on my JD bagger the bolts bolt through a plate and stay on the deck even when the deck is removed. Not sure if I'm making myshelf clear. The manual would help.
clueless
40 minutes ago, gwest_ca said:
Thanks Garry, I saw those but not showing how the chute bolts up. I'm sure you use the two bolts that hold the discharge chute on, same bolt hole pattern. Just don't know if you remove the discharge chute or not, mine is missing. Was hoping there might an operation/ installation manual, no big deal it will do what I want it do.
gwest_ca
I think what you want is on the first page of the operator manual
Garry
rlrnot
Remove the deflector chute and attach the bagger chute using the same holes and hardware.
clueless
Garry
Thanks Garry, once again you nailed it :thumbs:.
