LFDRET
Mower Deck Reinforcement Ring
LFDRET
Does anybody know where I could find a set of reinforcement rings for my 42in rear discharge mower deck. I have cracking around my spindlels and I am trying to repair it.
daveoman1966
I have 2 or 3.... send me an email and I';ll reply with details...price and shipping.
I am:
daveoman@windstream.net
jeff lary
I made one for my 37" deck  from 1/2 rebar last summer. I got the deck cleaned and treated underneath then I tack welded one end of the rebar to the far right or left side of the deck. Then with torches I heated the rebar while slowly bending the bar to fit the contour of the deck. I tack welded about every 4" or so the got the torch going again tack heat tack heat and so on till I was all the way around the forward portion of the deck. Then just went back and ran a bead of weld all the way around both inside and out.
gwest_ca
I believe the question was for something to reinforce the deck at the spindle assembly location.
I am convinced the cause of the cracks in this area is from running blades that are not balanced.
I don't know the dimensions of them or if these can be used for all spindles
https://www.partstree.com/parts/toro/parts/106117/
Garry
jeff lary
Yea I just re-read that I saw ring and I was thinking rod I guess, sorry carry on.
daveoman1966
Jeeeze...  $12 at Parts Tree...  I'll send you THREE of them for $15.... plus $3 to ship in USA.
Send payment to my Paypal or I'll accept a m.order ...
