PA.BOB 68 #1 Posted May 22, 2019 Hi everyone. Which snow plows would fit a 1967 1057 long frame? Like from what years would fit it ? And does it bolt to the bottom of the rear axle? With special brackets? I looked at some of the manuals . But i couldn't really find anything that much. I also wanted to see how it was mounted. Does it really mater what size i should run? I was thinking about a 42 inch. Any help would be greatly appreciated. Sorry for all these questions. Thanks. Bob...... Share this post Link to post Share on other sites
rjg854 11,350 #2 Posted May 22, 2019 This is the place for questions. Yes you'll need a long frame plow, an axle bracket to fasten the back of the blade to. A 42" or a 48" will work on your tractor. I'm sure some one will be along that can give you more specific information. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,033 #3 Posted May 22, 2019 Dozer DNA of long tractor frame dozer blades 1966-1967 model BD-426 - Fits LONG frame tractors - Mounts ahead of the rear axle - replaced by 1968 model 6-1111 - Fits LONG frame tractors - Mounts ahead of the rear axle ---------------------------------------------------------------------------------------------------------------------- 1968 model 6-4111 - First to fit LONG & SHORT frame tractors and first to mount under the rear axle - replaced by 1969 model [6-4112 + 6-9621] 1970-73 model [6-4113 + 6-9622] 1973-74 model [6-4113 + 6-9623] 1974 model [6-4114 + 6-9624] 1974 model 6-2131 1975 model 6-2132 1976 model 6-2133 1976 model 66-42BC01 1977 model 76-42BC01 1978 model 86-42BC01 1979 model 96-42BC01 1980 model 06-42BC01 1981-1984 model 06-42BC02 (Up to here they are 42" wide) 1984-1989 model 06-48BC01 (They are now 48" wide) 1990 model 06-48BC02 1991-1993 model 06-48BC03 1993-2001 model 79350 2002 2004-2009 2012 model 79364 Garry Share this post Link to post Share on other sites
The Tuul Crib 7,336 #4 Posted May 22, 2019 9 hours ago, rjg854 said: This is the place for questions. Yes you'll need a long frame plow, an axle bracket to fasten the back of the blade to. A 42" or a 48" will work on your tractor. I'm sure some one will be along that can give you more specific information. Share this post Link to post Share on other sites
