71_Bronco 1,072 #1 Posted May 19, 2019 I read on here on a previous thread that some decks are meant to "hang" from the tractor, and not ride along the ground, using the wheels to support the deck weight. I am going to be using a 5-2362 rotary 36" deck, and want to know if this should float on the tractor lift, or ride on the ground. I have an original WH manual for the deck on it's way (which I would also like to add to the manual section), but I'm not sure if the manual will address this. Thanks! Share this post Link to post Share on other sites
