JoeA
Looking for deck 312-8
JoeA
Hi First post looking for a cutting deck for an early 90's 312-8
Serial number 3112K801  11877
How big of a deck can I use ?
The original deck was a side discharge ? (42 I think )
In addition to the deck I need the assembly for the pulley assembly for the front of the tractor.
Does anyone have a picture they can post of the correct deck ?
Are these parts available new ?
Thank You for your help
Joe
Denver NC
ronwh
Joe,
Welcome to Red Square, you have found the right place for all things Wheel Horse.  I have a 48" deck on a 312-8 and it does a great job.  The pulley assembly that you need is called a mule drive.  You can do a search in the upper right corner for mule or 48" to see what you are looking for.
Thanks Ron
The Tuul Crib
Check the classified section to see what there is . You can also post in that wanted section as well .
I have a 48 on mine too. Im thinking
they came with a 42” deck
:text-welcomeconfetti:to:rs:
:wwp:
Edited by The Tool Crib
Racinbob
You shouldn't have any trouble finding one. With just a couple exceptions decks from 1973 to 2007 will work. I'm running a mid 70's 48" deck on my 2005 and the 05 42" deck is on my 76. :)
JoeA
Will a rear discharge deck also work ?
peter lena
yes rear discharge will fit, we all have our own preferences, i like the r/d , regular cleaning  and service adds years to service life, pete
gwest_ca
You will find this page handy. Click on the picture
Garry
JoeA
Garry
Thank You
  • Similar Content
    • SethL1984
      By SethL1984
      312-8 - Runs, new carb, ignition doesn't work. Was bought for parts, ended up being mower. Rear Attach-a-matic bracket
      417-8 - Runs well, electric lift, ignition may need cleaned (or started solenoid going). Rear Attach-a-matic bracket
      (1) 42" RD with mule drive. Cuts well!
      (1) 48" SD with mule drive.
      (1) 37" SD.
      (1)  48" snow plow. 5 way blade position I believe.
      Several other parts/WH odds/ends. One tractor does include the weights and chains.
      Parents are moving and, unfortunately, need to thin the herd!
    • Poppa Phill
      By Poppa Phill
      Ive Got an 88 520 and a 60 inch deck.
      My 522 gave up the ghost and being up here in maine I refused to buy a JD .
      Needing the deck mule with the spring,
      also looking for a soft cab.
      Thanks
    • tpsnowbanks
      By tpsnowbanks
      My double pulley deck drive spindle seized up and shredded the shaft.
      Looking for a replacement assembly.
      My rig is 310-8, 1986ish.
      The deck is 36" rear discharge. Similar vintage but has no identifying tags.
      The drive spindle on this one is front and center, not the older version with the tall spindle near the back.
    • lsc1257
      By lsc1257
      I have a 1996 520H Wheel Horse for sale.  The tractor has just over 800 hours on it.  It comes with a 48 inch deck.  The deck is a 1995 and has over 1,500 hours on it, as it came brand new with my 312-8 that I sold several years ago.  This 520-H has the swept front axle so it can handle a 60 inch deck.  I just replaced the battery and the deck belt this summer.  The engine is a 20HP Onan and it starts right up but requires the full choke.  The transmission is an Eaton 1100-062, hydrostatic.  The deck is in rough shape but the spindles appear to be in good working order.  The right rear tire has some cracking.  The original operator's manual for the 520H is included, as is the original operating and maintenance instructions for the deck, plus the installation instructions for the deck.  Also included is a new PTO belt and several miscellaneous deck wheels and rollers.  Additional pictures available upon request.  Asking $500.
    • BrianKoch
      By BrianKoch
      Gentlemen,
      I’m having trouble with getting my deck to raise up and lock and I think it might have to do with the deck being incorrectly set up.
      Based on the picture, does my mower deck look incorrectly positioned? That is, should the pivoting support bar be positioned above or below the wheel support pin?
      Brian
