SylvanLakeWH 25,600 #101 Posted December 6, 2020 Just going through whole thread... and... wow! Beautiful work!!! 1 Share this post Link to post Share on other sites
76c12091520h 3,623 #102 Posted December 14, 2020 Cleaned and inspected the entire wiring harness, re-taped everything with high temp 3M automotive electrical tape. Installed the harness and added extra hold downs and wire ties where possible, just trying to tidy up a mess of wires. Added one of Glens' fuse holder covers. Absolute worst part about this whole build...... Also put on a piece of tin. 3 10 1 Share this post Link to post Share on other sites
Tgalo 118 #103 Posted December 14, 2020 OMG this is just over the top beautiful! I wish I could see it in person, great work! 1 Share this post Link to post Share on other sites
AMC RULES 37,130 #104 Posted December 14, 2020 All this accomplished in only 5 pages! Outstanding work. 1 Share this post Link to post Share on other sites
JCM 9,177 #105 Posted December 14, 2020 Super nice job Brian, Would love to see that in person at the BS in June 2021. That would give any 420-LSE a run for it's money IMO . 2 Share this post Link to post Share on other sites
76c12091520h 3,623 #106 Posted December 15, 2020 Was able to save and re-install the decal that is usually found on the hydraulic cylinders. Actually remembered it BEFORE I put the covers on . 3 2 Share this post Link to post Share on other sites
76c12091520h 3,623 #107 Posted December 18, 2020 Finished installing the last of the sheetmetal and my spiffy new LED tailights. Also installed a really sweet reproduction parking brake lever...... 5 Share this post Link to post Share on other sites
WVHillbilly520H 10,373 #108 Posted December 18, 2020 What brand on the LED taillights? Optronics? Share this post Link to post Share on other sites
Fishgill 0 #109 Posted December 19, 2020 Great work. It looks awesome. Share this post Link to post Share on other sites
oneroadkingman 53 #110 Posted December 19, 2020 OMG this is just over the top beautiful! I wish I could see it in person, great work!❤❤is that res powder coated? Roughly how much money do u have tied up in this project if u don't mind telling? Share this post Link to post Share on other sites
76c12091520h 3,623 #111 Posted January 31, 2021 Have the engine torn down ( as far as it's gonna get ) compression was great, cylinders still have the crosshatch in them , so it's just getting mostly a good cleaning, detailing, fresh gaskets, carb rebuild, etc. Tins are getting blasted and I did both heads while I was at it. 2 1 Share this post Link to post Share on other sites
Raposo 530 #112 Posted February 3, 2021 Awesome work! Holy smokes! Are the rears 24x12x12? Share this post Link to post Share on other sites
76c12091520h 3,623 #113 Posted February 3, 2021 52 minutes ago, Raposo said: Awesome work! Holy smokes! Are the rears 24x12x12? Yep Share this post Link to post Share on other sites
76c12091520h 3,623 #114 Posted February 12, 2021 Went thru the carb and gave it and the intake manifold a little love. 4 5 Share this post Link to post Share on other sites
Reelhorsenut 4 #115 Posted February 16, 2021 Looking darn good! Leaking intake manifolds are a known issue. Several threads here about resealing them. If you don't want to split the intake apart, at minimum it's a good idea to replace the rivets with nuts and bolts, one at a time. Loctite them. Then scrape off the visible rtv and go along the seam with new high temp rtv. Eliminates 99% of any future vacuum leaks. Splitting and resealing gets you to 100%. Can't wait to see the final pics!!! 1 Share this post Link to post Share on other sites
Handy Don 12,235 #116 Posted February 16, 2021 On 2/11/2021 at 11:12 PM, 76c12091520h said: Went thru the carb and gave it and the intake manifold a little love. Ultrasonic tank? Looks almost new! 1 Share this post Link to post Share on other sites
lynnmor 7,308 #117 Posted February 16, 2021 See that cut on the side of the intake just below the vacuum connection? Grind away a bit of the heat shield that cuts it there. Also look for cuts elsewhere. 1 Share this post Link to post Share on other sites
Horse Newbie 7,075 #118 Posted February 16, 2021 (edited) 4 hours ago, lynnmor said: See that cut on the side of the intake just below the vacuum connection? Grind away a bit of the heat shield that cuts it there. Also look for cuts elsewhere. I had that same notch where my front exhaust heat shield was rubbing the intake manifold...never would have noticed it had it not been for you guys! It's good now since I trimmed a little off the heat shield. Edited February 16, 2021 by Horse Newbie 1 Share this post Link to post Share on other sites
Horse Newbie 7,075 #119 Posted February 16, 2021 (edited) I opted to not split my intake into 2 halves...but I'm sure I got a good seal with the RTV that I used to seal the seam after a good cleaning...the RTV cured almost as hard as metal, and was I was not able to dig my fingernail into it. Edited February 16, 2021 by Horse Newbie 1 Share this post Link to post Share on other sites
Greentored 3,214 #120 Posted February 16, 2021 Beautiful work!!!!! Share this post Link to post Share on other sites
Handy Don 12,235 #121 Posted February 16, 2021 @Horse Newbie, is RTV a silicone caulk? Hope I am not raining on your parade, but are you sure that stuff is ok for exposure to gasoline and for high heat? Only a very few Permatex products are gasoline rated. 1 Share this post Link to post Share on other sites
Shed 248 #122 Posted February 16, 2021 Motoseal is what I use for all intakes kinda runny one of the only gasket maker made for fuel exposure https://www.permatex.com/products/gasketing/gasket-makers/permatex-motoseal-1-ultimate-gasket-maker-grey/?locale=en_us 1 1 Share this post Link to post Share on other sites
Horse Newbie 7,075 #123 Posted February 17, 2021 3 hours ago, Handy Don said: @Horse Newbie, is RTV a silicone caulk? Hope I am not raining on your parade, but are you sure that stuff is ok for exposure to gasoline and for high heat? Only a very few Permatex products are gasoline rated. Don't look at it at all like you are raining on my parade...you are just asking a question, trying to be helpful. To be honest, I may have described what I used incorrectly. I'll have to try to find the package( if it hasn't been tossed) and see if it was/is suitable for the application in which I used it. I do believe whatever I used, I read the package, and it was compatible with exposure to gasoline. What does it look like to you if you can tell by the pic I shared ? Share this post Link to post Share on other sites
Horse Newbie 7,075 #124 Posted February 17, 2021 3 hours ago, Shed said: Motoseal is what I use for all intakes kinda runny one of the only gasket maker made for fuel exposure https://www.permatex.com/products/gasketing/gasket-makers/permatex-motoseal-1-ultimate-gasket-maker-grey/?locale=en_us @Handy Don , @Shed That's it ! That's what I used ! Thanks...now since I kinda took this thread off topic...man that 520H restore is unbelievable ! Outstanding talent and attention to detail ! @76c12091520h Share this post Link to post Share on other sites
Handy Don 12,235 #125 Posted February 17, 2021 Glad to hear that it was "the good stuff". That job is not one to look forward to repeating. Keep up the good work on the 520--they are very impressive machines. 1 Share this post Link to post Share on other sites
