Lee1977 6,659 #76 Posted August 3, 2020 On 2/18/2020 at 7:57 AM, pullstart said: Is that round bar an addition? Seems it would really help to keep that hood from rocking around It's not round it is about 1/2" x 1/8". Was added to those models at some point. my 312-8 and 1989 520-H have them. Not sure what year they were added. The early models didn't have them. Share this post Link to post Share on other sites
76c12091520h 3,620 #77 Posted August 5, 2020 Installed the brake band and linkages/hardware , new original Toro / Wheel Horse hydro filter , castle nuts , cotter pins , grease fittings , and boots on the tie rods. Also made up and installed some soft bump stops for the front axle; no more chipped paint. 8 6 Share this post Link to post Share on other sites
tom2p 2,394 #78 Posted August 6, 2020 you're just showin off ! outstanding job ! 2 1 Share this post Link to post Share on other sites
AMC RULES 37,130 #79 Posted August 6, 2020 Oh man! You're gonna be sooo bummed out when that chip suddenly appears out of no where. 1 Share this post Link to post Share on other sites
76c12091520h 3,620 #80 Posted August 7, 2020 Installed the center "console" , the lift linkage, the drive belt idler, the hydro cylinder, and some new hardware. 1 7 1 Share this post Link to post Share on other sites
Pullstart 62,879 #81 Posted August 7, 2020 Forgive me for my ignorance y’all, I noticed the combination of a hydro and a brake band? Is this the only tractor equipped as such, or is every Eaton 1100 this way? Share this post Link to post Share on other sites
pfrederi 17,739 #82 Posted August 7, 2020 4 minutes ago, pullstart said: Forgive me for my ignorance y’all, I noticed the combination of a hydro and a brake band? Is this the only tractor equipped as such, or is every Eaton 1100 this way? All 1100 Eatons have a physical brake, Later model Sunstrand piston to piston also had a physical band brake. Share this post Link to post Share on other sites
bds1984 1,429 #83 Posted August 7, 2020 Every Eaton 1100 machine I have owned has the same (C175, C195, C145, 416H, 520H). Share this post Link to post Share on other sites
Pullstart 62,879 #84 Posted August 7, 2020 Huh. I learned something! 1 Share this post Link to post Share on other sites
76c12091520h 3,620 #85 Posted August 8, 2020 Installed the new cooling fan, some of the seat / gas tank brackets, more of the hydro linkage, the engine plate, and the Attach-a-matic brackets. 4 Share this post Link to post Share on other sites
cleat 5,977 #86 Posted August 8, 2020 Your project is coming along beautifully. Just one thing. Your engine plate is upside down. Hate for you to get the engine bolted down to it then have to switch it. 1 Share this post Link to post Share on other sites
76c12091520h 3,620 #87 Posted August 8, 2020 Up at 5 am + 12 hr day + still in garage at 10 pm = D'OH 1 Share this post Link to post Share on other sites
76c12091520h 3,620 #88 Posted August 8, 2020 Fixed it ! Just knowing it was wrong would've kept me from functioning properly all day. I'd have caught it eventually but thanks cleat ! 3 Share this post Link to post Share on other sites
76c12091520h 3,620 #89 Posted August 10, 2020 Installed the fuel tank, good original sending unit (have a NOS but why waste it) and a new gasket, and installed the rest of the lug nuts on those spiffy new wheel studs: 2 1 Share this post Link to post Share on other sites
76c12091520h 3,620 #90 Posted November 4, 2020 Installed the gauges / instrument panel and the motion and height controls 4 Share this post Link to post Share on other sites
Pullstart 62,879 #91 Posted November 4, 2020 So perfect! Your work is so good, so many details! 1 Share this post Link to post Share on other sites
jeremi3210 717 #92 Posted November 5, 2020 This is gonna be one fine looking 520! Can't wait to see the finished product!!! Great job!!! Share this post Link to post Share on other sites
76c12091520h 3,620 #93 Posted November 5, 2020 10 minutes ago, jeremi3210 said: This is gonna be one fine looking 520! Can't wait to see the finished product!!! Great job!!! Thanks Share this post Link to post Share on other sites
76c12091520h 3,620 #94 Posted November 5, 2020 Installed the steering shaft and wheel (didn't forget the ANTI-SEIZE ) and the pto safety switch and bracket(with a serrated stainless bolt). Shimmed the steering column as needed to remove play in the shaft, and also installed some hard fiber washers on the control levers to eliminate any slop. 4 Share this post Link to post Share on other sites
76c12091520h 3,620 #95 Posted November 12, 2020 Went back into the hydraulics and swapped out the long hose that runs to the bottom of the rear axle, switched it over to a newer style hard line instead of the rubber hose. It routes completely different (under the lift/hydraulic mechanisms instead of over the top, really cleans things up in the center console area. installed the hood hinges, put a small section of heat shrink on the stops for the hood hinges so there isn't any metal on metal contact, installed the pto lever and installed a foam pad where it contacts the stop, and installed the front closure panel with the relays on it. 7 Share this post Link to post Share on other sites
Pullstart 62,879 #96 Posted November 12, 2020 Are those hard lines custom, or just a later design? I wonder if any other tractors could be made into hard lines? Share this post Link to post Share on other sites
dclarke 4,032 #97 Posted November 12, 2020 Excellent work you're doing, love the attention to detail! Keep the pics coming. 1 Share this post Link to post Share on other sites
Zeek 2,286 #98 Posted November 12, 2020 Nice job! That is a very nice restoration! It's all about that details . . . Share this post Link to post Share on other sites
76c12091520h 3,620 #99 Posted November 12, 2020 6 hours ago, pullstart said: Are those hard lines custom, or just a later design? I wonder if any other tractors could be made into hard lines? The hard lines are factory correct for newer 520's(mine's a 91). I would have liked to changed out the other long hose too, but the tins are different in the area around the lines and I wasn't cutting sheetmetal at this point. 1 Share this post Link to post Share on other sites
76c12091520h 3,620 #100 Posted December 6, 2020 Got the fuel line cut and ready to install: 2 2 Share this post Link to post Share on other sites
