RandyLittrell 3,877 #1 Posted May 10, 2019 (edited) Will the axle brackets I have on my GT-14 work on my 310-8. They look like they should, but thought I would ask before pulling them off the 310. Thanks, Randy Edited May 10, 2019 by RandyLittrell Share this post Link to post Share on other sites
peter lena 8,583 #2 Posted May 10, 2019 the brackets need to be turned down, the nuts should be on top of the axel housing , suspending the hanger points. the rear mounting point bar on the plow frame will verify that , pete Share this post Link to post Share on other sites
WVHillbilly520H 10,373 #3 Posted May 10, 2019 10 hours ago, RandyLittrell said: Will the axle brackets I have on my GT-14 work on my 310-8. They look like they should, but thought I would ask before pulling them off the 310. Thanks, Randy I believe the GT14 are different from the B,C,3,4,500 series tractors... @wheelhorseman, check his website...https://wheelhorsepartsandmore.com/brackets-linkages.html ... Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,033 #4 Posted May 10, 2019 Early dozer models had the bracket the plow connects to mounted on the front of the axle housing like the GT-14 you show. Later the bracket was bolted to the bottom of the axle housing. If the dozer and brackets are from the same era it may work - I don't know. Garry Share this post Link to post Share on other sites
RandyLittrell 3,877 #5 Posted May 10, 2019 Thanks guys, I didn't even think of looking on Wheelhorsemans site. Thanks guys, I will just buy some for the 310. Randy Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,033 #6 Posted May 10, 2019 The GT-14 A-frame in the 310 brackets will move the A-frame back about 2" to 3". Will it still work? Garry Share this post Link to post Share on other sites
