RandyLittrell
Axle brackets for blade
RandyLittrell
Will the axle brackets I have on my GT-14 work on my 310-8. They look like they should, but thought I would ask before pulling them off the 310.
Thanks, Randy
Edited by RandyLittrell
peter lena
the brackets  need to be turned down, the nuts should be on top of the axel housing , suspending the hanger points. the rear mounting point bar on the plow frame will verify  that , pete
WVHillbilly520H
Thanks, Randy
I believe the GT14 are different from the B,C,3,4,500 series tractors... @wheelhorseman, check his website...https://wheelhorsepartsandmore.com/brackets-linkages.html ...
gwest_ca
Early dozer models had the bracket the plow connects to mounted on the front of the axle housing like the GT-14 you show.
Later the bracket was bolted to the bottom of the axle housing.
If the dozer and brackets are from the same era it may work - I don't know.
Garry
RandyLittrell
Thanks guys, I didn't even think of looking on Wheelhorsemans site. Thanks guys, I will just buy some for the 310.
Randy
gwest_ca
The GT-14 A-frame in the 310 brackets will move the A-frame back about 2" to 3". Will it still work?
Garry
