Countdown To Christmas!
Similar Content
By t_furl43
A Wheelhorse C-165 8 speed, nice solid tractor everything works and operates as it should, all lights works(stack will be removed before sale)unknown hours it was only an option for the 165, but the 16hp single lung cast iron K series motor starts right up and runs strong. It will need new motor mounts. Transmission shifts smooth, package comes with plow w/optional down pressure bar if you choose instead of your trunnions chain, a set of tire chains, a set of Toro brand front wheel weights and a set of generic rear wheel weights, and lastly a full set of hub caps that are in decent shape they can be cleaned up, $1000 obo. Would like to sell as package but if the right buyer was interested in the right combo of stuff for the right amount of money we could work something out. Pickup only in Millersville PA 17551
By firstimpauto@gmail.com
1977 C160 Automatic Tractor. This has been my go to tractor for over 30 years. Not a show tractor by any means. Could definitely use a tune up but still runs and mows. Included are original manuals, 2 mowing decks, cab ( which needs all the windows replaced) including the doors and tire chains. Someone modified the plow so it doesn't really fit this tractor. I purchased a larger machine so do not have a need for this. Hydraulic lift is not working. One front tire has a slow leak. Open to offers. Thought I had this sold but it was someone trying to scam me with a phony cashiers check. Please be careful. This is the only site I have this listed so the scammer must be monitoring these ads. Sold the rototiller. So adjusted the price.
By Upnorthman
314-8 In great shape. Used for mowing more than anything. Bought it a few years ago but got a new tractor. I used the blower very little and it sounds like it needs a bearing on it. Runs well. I have new chains I've not put on yet and extra belts.
By Brockport Bill
Here comes the snow!!! 48 inch Front Plow unit - Model #0648bc02. Ready for snow, dirt, gravel, stone or any chore. Pick up Poughkeepsie, NY area -- $290
By Burnerman
Had the day off so I figured I’d get the plow situation set while I wait for mower deck parts.
I have the rear tires weighted to 90# ea. The old ag tires are dried out and have some cracks but still hold air tubeless. I have a set of chains but they do a number on the driveways I plow. I see a tire spray that’s supposed to improve traction. Anyone ever try it? Is there something out the to soften old rubber? I the really don’t wanna drop $160 on new tires when these still hold air. 😁
That’s my 4”x3/16” plow edge. It’s a 50” long piece I got from the cut pile at the local steel yard. It was cheap and has lasted a long time. I flipped it for the first time.
I may put tubes and fill my fronts with RV antifreeze. I’m also gunna make a downpressure link soon.
I haven't used it to plow in about 5 years due to transmission issues that are now solved and some timing adjustments that quelled almost all of my engine knocks.
