ET160
B80 4 Speed Belt--Too Short?
ET160
I got my transaxle back together, including a new 7473 belt, which seems to have a problem.
When I push down on the clutch lever the trans doesn't disengage, and I can't put it into gear.
Is the belt too short?  That's the only thing that I can think of.
953 nut
You don't have the belt guard on do you?
Edited by 953 nut
ET160
I do.  I just bought another belt, so I'll see if that helps.  I thought the 7473 was right for my 1975 B80.
ET160
No happiness.  I changed the 7473 Toro belt (new) for a Napa B80 belt.  It disengages, but is very jerky letting off.
pfrederi
Does your belt guard have tabs on the front and are they adjusted to be very close to the belt.  They channel the belt to help disengagement.
ET160
Yes.  I got some more belts to try, some True Blue from Ace.  The 5/8 x 82 doesn't get me into gear.
The best so far has been a NAPA B80 5/8 x 83, but I took that back as it was jerky letting off.
I'm wondering whether 5/8 x 82.5 is maybe my best bet.  I see those exist.
I just don't understand why everything is so difficult.
