Retired Wrencher
#48 105052 LINK-LIFT
Retired Wrencher
Hi This goes between the lift arm on tractor and the plow with pins and clips. Does any one have the dimensions this part ? would like to make one up. Should not be that difficult to make. I do not like the chain set up on it now. Thanks in advance.
ebinmaine
Gary I've got one on the plow that I use for my B and C series tractors.
I can measure it for sure when I get home but I feel like it's made out of steel that's about 1  1/4 or 1  1/2 in wide.
1/8 in or 3/16" thick would be fine.
Total length is 11.25 and the pin Center is somewhere around 10 or 10 .25.
ebinmaine
Handy for down pressure.
gwest_ca
Would it be a little over 5" long with the holes centered on about 4"?
https://www.partstree.com/parts/toro/parts/105052/
Garry
Found this. Click on the drawing.
Retired Wrencher
Thanks Eric. I would like to see a pic of it so I know this right part.
Edited by Retierd Wrencher
Retired Wrencher
20 hours ago, daveoman1966 said:
Buy a NEW part 105052 here for less than $20.
 https://www.psep1.biz/arinet.asp?aribrand=TO#/s/TO//105052/1/
Thanks D but no pick of it. I hope this is the right part.
Retired Wrencher
Garry
Thanks Garry. This not clear if this is the right part. I do not see the lift holes.
Retired Wrencher
Eric is this the part? Just need length of part and distance between holes Thanks.
ebinmaine
Gary, mine is the longer one. That one looks more like Garry above is describing. 5.5 inches maybe.
I'd go by the blueprint for the shorter of the two that he posted.
The one I have is for a slightly different setup and does not use the horizontal bar such as in that picture. It goes directly up to the lift lever.
Retired Wrencher
Ok thanks Eric.
gwest_ca
This photo is of the short link on a 1" square grid.
If you click on the drawing above it will take you to another picture of how they are used.
Garry
Retired Wrencher
Garry
Thanks Garry.
I see it now in the drawing . Need more coffee.
