Pierrepont
5xi Mower Deck DRIVE Belt SIZES?
Pierrepont
What length or model DRIVE belt sizes fit the following 5xi mower decks?
- 42"
- 48"
- 60"
Thanks
gwest_ca
Click on the pictures. The belts are listed on the page that comes up. Nothing to download unless you want to. Best to search for the proper belts by using the model number and serial number of the mower deck. They may not all be the same.
Garry
WVHillbilly520H
gwest_ca
Have added many belt numbers and sizes to the page that describes the file for the deck's parts lists. Saves downloading a file to find out the belt sizes.
The belt charts do have mistakes in them so when I see the opportunity to check numbers like above I do it. This time I think there is a mistake in the decal.
105-1491 (5/8" x 94") drive belt for 42" deck on decal - This is correct but the deck is a rear discharge 1998-2001. The 5xi never got a 42" side discharge deck.
95-4095 (5/8" x 98") drive belt for 44" deck on decal - This belt fits the 48" decks 1998-2001 when the front idler assembly had the adjustment knob on the front.
105-1490 (5/8" x 98.5") drive belt for 48" deck on decal  - This belt fits the 48" decks 2002-on when the front idler assembly had the adjustment knob on the bottom.
95-4094 (5/8" x 96.7") drive belt for 52" deck on decal - This belt is correct but also used with 44" decks
105-1491 (5/8" x 94") drive belt for 60" deck on decal - This is correct
The 105-1500 decal shows up 2002-2006 and was on the front panel of the idler assembly.
Hope I have this right.
Garry
