ET160 29 #1 Posted April 26, 2019 (edited) I'm having some difficulty finding an axle shaft for my B80 (1" dia, 10.5" length). I may be able to get one for a B60. Are they the same by chance? Edited April 26, 2019 by ET160 Share this post Link to post Share on other sites
ebinmaine 68,389 #2 Posted April 26, 2019 (edited) I don't have the answer as to whether a 60 and an 80 is the same. I kind of thought the 60 was smaller but I've never seen one in person. I'll check my shelf when I get home. I don't know if I have any of those axles. Have you tried A to Z tractor? Edited April 26, 2019 by ebinmaine Correct, autocorrect. Share this post Link to post Share on other sites
Goldnboy 945 #3 Posted April 26, 2019 The b60 is a clone (less lights and electric start)to a c120/c160 and uses the 1 1/8" axles. Be careful of B80 parts the 74-75 used 1" axles, 76-77 used 1 1/8". Share this post Link to post Share on other sites
ebinmaine 68,389 #4 Posted April 26, 2019 I'm kind of thinking that a lot of the three or four speeds use the same axle shaft provided they had the correct C clip or pin set up. I'm sure one of the experts will be along at some point. Share this post Link to post Share on other sites
Stepney 2,325 #5 Posted April 26, 2019 I never understood the B-60. The ones I have seen use the 1 1/8" axle with the heavier duty differential .. then the B-80 model. Anyway, the answer is no, depending on the year. But maybe off a later model? Sorry not much help here. Share this post Link to post Share on other sites
