seven 202 #1 Posted April 26, 2019 Keeps wanting to slip out of 3rd gear?. Would like to get it fixed but don't know where to start and if it's a bad gear can I get new gears. Any help would be appreciated Share this post Link to post Share on other sites
953 nut 55,792 #2 Posted April 26, 2019 Probably your 3523 gear (high/2nd) is the problem because some one was shifting on the fly rather than coming to a complete stop. You can get a new one from Lowell https://www.wheelhorsepartsandmore.com/transmissions.html#!/3523-3rd-gear/p/84932562/category=23548039 While you are at it this is a good time to renew all the seals and your axle bearings too. This thread will show all the steps. 1 Share this post Link to post Share on other sites
seven 202 #3 Posted April 26, 2019 Nice I'm going to probably need PARTS? Always the big question gasket to go around case. news axle seals . New gear. Are they still out there available? Share this post Link to post Share on other sites
ebinmaine 68,370 #4 Posted April 26, 2019 ALL of those parts are available from Lowell at Wheel Horse parts and more. that's a pretty easy fix to do. Basic mechanical tools and some care and caution and cleaning. Share this post Link to post Share on other sites
oliver2-44 9,867 #6 Posted April 26, 2019 (edited) When your ready to dig in to it, flush the transmission with diesel or kerosene. Just drain the gear oil and put 2+ quarts of diesel in the transmission. Drive it around shifting into each gear for about 15 minutes. Jack up the front of the tractor when you drain the diesel to get what trapped by the hump in the bottom of the transmission. If the gear oil was really gray/brown and the diesel flush looked really dirty, i have flushed them with diesel a second time. This sure make it a little cleaner job when you split the transmission open. Edited April 26, 2019 by oliver2-44 1 Share this post Link to post Share on other sites
seven 202 #7 Posted May 5, 2019 It's open now looks terrible for sure high gear some other ones don't look to good either. Think I will get by with a gear gasket and axle seals . Share this post Link to post Share on other sites
stevasaurus 22,866 #8 Posted May 5, 2019 Can you post some pictures of those other gears?? Share this post Link to post Share on other sites
ebinmaine 68,370 #9 Posted May 5, 2019 4 minutes ago, stevasaurus said: Can you post some pictures of those other gears?? Share this post Link to post Share on other sites
seven 202 #10 Posted May 5, 2019 Tried but it won't allow me? Share this post Link to post Share on other sites
ebinmaine 68,370 #11 Posted May 5, 2019 5 minutes ago, seven said: Tried but it won't allow me? Probably reach your max postings. If you become a supporting member there is no max. And no ads. Well worth it, and helps keep the lights on around here. Share this post Link to post Share on other sites
seven 202 #12 Posted May 6, 2019 All I have to do is buy something Share this post Link to post Share on other sites
ebinmaine 68,370 #13 Posted May 6, 2019 5 minutes ago, seven said: All I have to do is buy something I don't know how to get to the link from my phone... Perhaps @stevasaurus could give it to you. You'd become a supporter and have your name in red. Share this post Link to post Share on other sites
pfrederi 17,881 #14 Posted May 6, 2019 https://www.wheelhorseforum.com/store 1 Share this post Link to post Share on other sites
ebinmaine 68,370 #15 Posted May 6, 2019 16 minutes ago, pfrederi said: https://www.wheelhorseforum.com/store Nice! Thank you Paul. Share this post Link to post Share on other sites
