Countdown To Christmas!
RJ Hamner
To Rebuild or Not to Rebuild...That is the Question
RJ Hamner
Just started a ground up restore on a 1968 Raider 12.  Step ! was going to be the transmission.  Made a cradle/work table and armed myself with all the required manuals.
I just split the case this afternoon and was amazed at what I found.  I had rebuilt the transmission on my 60 Suburban and had sludge chipped teeth and a broken casting.
I found none of that.  The guy I bought it from told me that 3 of them had used the Raider to mow a small cemetery until they got too old and or hired a contractor to do it.
They either took extremely good care of it or this is a replacement or was rebuilt a while back.
The pictures are "as opened". the only thing I have done was wipe the excess oil out of the one case half.
Cast you well trained eyes (I don't consider myself anywhere near an expert on transmissions) ((wife says I am barely housebroke))
I would appreciate your opinions on wither or not I need to do a complete rebuild.
As a side note:  All the ball and needle bearings are clean and rotate freely;
Thanks
Bob
  • Like 3
  • Excellent 2
ebinmaine
Two things.
"Barely" housebroke... Is still housebroke. You get credit for that.
Now as for that transmission I'll leave it to the actual experts and not me. But my inclination on that would be to open up the differential and check that over and then
Replace the four seals.
But probably leave the rest of it alone.
857 horse
Just a thought......i see your in md,,,,,,,
the BIG SHOW (all wheelhorse)  is a few miles from gettysburg pa....
Someone is gonna have one for sale,,,,,,,200 venders,,,,,1000 people...500 red tractors.....
and you will have a ball......
just a thought...!!!!!!   good luck......seee you there!!!!!!!!!!!!!!!!!
RJ Hamner
This will be my 3rd year.  Always have a great time and come home with LOTS of "stuff"
The wife has fun too.  As a matter of fact Joette Scholljegeedes and my wife were "tag teaming" my Visa card.  They even sic'ed the kids on me
Bob
Edited by RJ Hamner
forgot to add a line
JoeM
Hey Bob looks good, If your just going to Sunday drive it, lever B. I am with EB; seals, fluid and paint!
  • Thanks 1
RJ Hamner
Hi Joe
Thanks kinda what I was thinking.
So now if it falls apart I can tell the wife "Joe said it was OK":lol:
Bob
  • Haha 2
JoeM
LMAO I love you to!
  • Haha 1
Racinbob
When I got my 76 back after 17 years in somebody else's hands I opened up the tranny to inspect it and it looked like that. I closed it up, new seals and go juice and felt good knowing that it was in good hands during that time. :)
stevasaurus
Nothing wrong with that trans and the gears.  It's always a good feeling to know what you have in there.  :occasion-xmas:
RJ Hamner
Just ordered the gasket and seals.
Thanks for the input:D
Bob
ET160
Looks great!  It doesn't look like it ever ran low on gear oil or had any water in the case.
  • Similar Content
    • giant_g2
      By giant_g2
      Not sure on specific model. This 8 spd came attached to a plow I bought. It had some water in it for a couple weeks according to the prior owner. I drained it, sloshed some diesel in it, drained that, then filled with fresh oil. Spinning the input shaft by hand, I can see the axels turn. Hasn't leaked any oil. I'm not really interested in shipping, so I'd prefer local sales.
    • Doug B
      By Doug B
      Hey guys,I have a dilemma I need some help with. I have a 1969 GT 14 that I replaced the transmission and pump on. For about 2 weeks afterward everything worked great, but while mowing at a pretty good pace I noticed a shudder and the tractor slowed a little but not bad. The more I rode it the slower it got until it barely moves. What stumps me is the hydraulics are still very strong,as in I can back the 3 point under the bumper of my truck and if you lift the arms all the way up the front wheels of the tractor will clear the ground. Have checked the tow valve and checked the internal filter,but no luck. I have also checked and replaced the forward and reverse bypass springs and the lever is moving the cam to full travel, forward and reverse. Any help would be appreciated.
    • mattd860
      By mattd860
      I have developed a kit that allows a Wheel Horse / Toro hydrostatic tractor to be operated by a pedal on the right side of the tractor. The original forward/reverse lever can be retained or removed. The kit includes everything needed to install the pedal kit and installation is simple with the help of a downloadable installation manual. Additionally, only one (1) 1/4" hole will need to be drilled which can be done by a hand drill. No other drilling or cutting will be necessary. Any tractor with this kit can be converted back to stock without any visible evidence that kit was installed. However, you'll never want to do that
      The foot pedal is custom cast in Aluminum, uses brass bushings to minimize wear, and it closely matches the OEM Wheel Horse BRAKE pedal commonly found on 8-speed manual transmission tractors. Modifications were done to the pedal to add the reverse pedal and adapt the pedal to the rest of the kit. For the most part, the pedal looks like it was designed and manufactured by Wheel Horse / Toro. Additionally, a grease fitting has been adapted to the pedal to further minimize wear and tear and if the brass bushings ever wear out they are fully replaceable without having to buy a whole new pedal.
      Here is a link where you can download the installation manual: CLICK HERE
      I am selling these kits for $330 shipped to anywhere in the United States. I offer multi order discounts as well. I will also sell to other countries for additional shipping charges to be determined.
      Thanks!
    • Dylan2342
      By Dylan2342
      New here! hello everyone! In a bit of a pickle here. My father owns a 1993 (I think that is the right year) 520H Wheel Horse. I don't commonly work on tractors but it seemed simple enough. the axle snapped on the left side, so it needed a new transmission. My dad bought a used transmission and I went to work changing everything out. The hydraulic pump that the engine's drive belt attaches to went to a different model/year of tractor, so I had to remove that part and swap it in from the old transmission. In the process I lost all of the oil in the pump (I mention this because I wonder if it has to do with my problem I'm having). When I reassembled everything I started the slow process of filling the transmission. I filled it up and started the engine. When moving the lever forward or backward, it had a tiny bit of power for a little bit and then lost power. The transmission wasn't doing anything, anymore. I though maybe that hydraulic pump needed to be primed, so we took the top hydraulic line off of the hydraulic pump right above the drive belt and used a transfer pump to pump some oil into the pump case. This still didn't work. I don't have enough experience with these hydrostatic transmissions to know if we got a bad transmission or if there is something obvious that I am missing when it comes to a transmission swap. I ask for any insight and help please. If you need pictures or any other info, then let me know what you need. Thank you!
    • Porkskin
      By Porkskin
      I have no understanding of what it is like to push one of these when the trans is disengaged and motion lever is in the forward position as the manual mentions. I hope this is not old ground and that I am not cross posting. With the trans disengaged and motion lever set forward there is still something spinning in and about the transaxle that is giving resistance. I need to know if this is normal or if I should be expecting more of a free wheeling experience. In effect, much less resistance. Thank you for comments or pointing me to a topic that already covers this.
