Larry Chamberlain
K301 PTO loop
Larry Chamberlain
Are the loops all interchangeable  on the wheel horses I'm trying to use the one off of my old 8hp on 12hp
troutbum70
I would think if it fits and everything lines up it should work.
pfrederi
There are at least two different size PTO loops. But like Trout said if it lines up use it.
Edited by pfrederi
peter lena
remember that the top angular engagement plate ,can also be used  UNDER the engine mount for a clearance/ fit issue. just put the upper bronze bushing , under the plate on the bottom. letting you still use the lever rod engagement point, but at a different level, pete
