Dano101 32 #1 Posted April 15, 2019 I’m sure it’s on here somewhere but not quite sure how I would find it. Just curious If anyone knows the seal number for the axle seals on a d160? Thanks Dan Share this post Link to post Share on other sites
The Tuul Crib 7,337 #2 Posted April 15, 2019 31 minutes ago, Dano101 said: I’m sure it’s on here somewhere but not quite sure how I would find it. Just curious If anyone knows the seal number for the axle seals on a d160? Thanks Dan Look above in this section it should give you the numbers you need. Napa has those seals too. 1 Share this post Link to post Share on other sites
953 nut 55,806 #3 Posted April 15, 2019 You could do a little measuring to be sure. The axles are 1.125 outside diameter so there are a couple of common seals that could fit. If the O.D. of the seal is 1.375 +/- then you meed a "SKF 11050"; if the O.D. of the seal is 1.625 +/- then a "SKF 11123" is needed. Any good auto parts store can get them for you. 1 Share this post Link to post Share on other sites
Dano101 32 #4 Posted April 16, 2019 20 hours ago, 953 nut said: You could do a little measuring to be sure. The axles are 1.125 outside diameter so there are a couple of common seals that could fit. If the O.D. of the seal is 1.375 +/- then you meed a "SKF 11050"; if the O.D. of the seal is 1.625 +/- then a "SKF 11123" is needed. Any good auto parts store can get them for you. Thanks for the input I guess I’ll have to rip it apart. I was hoping to have seal on hand before taking apart. Thank you though! Share this post Link to post Share on other sites
pfrederi 17,885 #5 Posted April 16, 2019 All sundstrand use the same axle seals. WH 6449 SKF 11124 Share this post Link to post Share on other sites
