12 hp Kohler
My new gt14
Aldon
  On 4/13/2019 at 1:00 AM, pullstart said:
Never say never!  Aim high and work hard, I bet @Aldon‘s got some sweat equity into those wheels 👍
A ton of sweat equity but a lot of $$ too:-)
Not to mention the high quality welding skills of @fast88pu
  • Like 4
12 hp Kohler
I wouldn’t bet against it either :lol: I had the privilege of watching Kevin put 4 tractors in the Colorado last year at the show. I don’t know how he does it but it can be done :blink:
Edited by 12 hp Kohler
  • Haha 6
19richie66
I love how everyone drills out the side of the dash housing and puts the throttle there. Same thing on the one I parted. That one should clean up nice. I definitely would preserve it the way it is. Paint the wheels, new set of tires and get it mechanically sound and it will be a nice survivor. Good luck with it. I had fun building Skittles, although she looked way worse than that when I got her.
Pollack Pete
VERY nice GT-14.I have 5 or 6 of them myself.I  see by the exposed fuel tank that it's an early one.Later ones had the full cast iron grill protecting the tank.Be careful you don't run into anything and poke a hole in that plastic tank.Have fun with your new toy.
Super-C 4 me
  On 4/12/2019 at 6:16 PM, 12 hp Kohler said:
Do you guys know where I can get rear tires for the GT14. I would like to get ag tires but if I can’t I will settle for turfs.
I believe someone has set for sale in the classified adds
953 nut
Page 5 of this post has turfs for sale
Super-C 4 me
I stand corrected, that where I saw it.
12 hp Kohler
I looked at the gas tank a little bit and it is in really bad shape, I’m not sure if it is salvageable. I’m not sure if it could be repaired or not. I will take some pictures of it tomorrow and you guys can give me some pointers.
bellevillerod
Nice looking machine I have my eyes open looking for a nice gt for myself. Looks like you have a good candidate for a restore if that's what you want to do.
fast88pu
  On 4/13/2019 at 2:21 AM, pullstart said:
All those naysayers...  doubting me so often :D  Someone sponsor me 4 GT14’s, I’ll see if I can get ‘em in the Colorado!
One rule this year is you can't take them apart lol
  • Haha 3
953 nut
@Aldon has a thread on his repair of a GT_14 gas tank someplace. I will look for it later, headed to church now.
19richie66
halfway down page 4
ztnoo
  On 4/14/2019 at 1:29 PM, 19richie66 said:
halfway down page 4
Post #79
Edited by ztnoo
12 hp Kohler
Here is picture of the fuel tank. The whole top of it is cracked and bent up. It’s already been repaired but the repair broke. D8F92616-8F62-4116-97E0-D97E5E07D0F8.jpeg.f3c00c32fac0267063fcc35900f011f2.jpeg
  • Sad 2
oldredrider
These tanks are getting hard to find in good condition. I had one where the bottom was cracked almost all the way across. Sent it to a friend who had a plastic welder. Came back all sealed up and stayed that way. Do a search on Google regarding plastic welding if you can't find a replacement tank.
19richie66
Soldering iron and black zip ties. Groove the crack with the tip of the iron, melt a zip tie into the groove and work back and forth till it is melted into the tank. Being it is on the top, it’s not as critical and you can sand it and seal it
  • Like 6
12 hp Kohler
Took the tiller off today and got the engine running. Runs okay but needs carburetor work, carb is really worn out. I have a video of it running but I’m not sure if it will work. Let me know if it works or not. BF0862BB-A0D4-45A7-B811-C86CD1C3A8D5.jpeg.5120c43a10395f768cde7406e836cfa4.jpegAC6BC641-C9B7-40EA-ADC2-6DB0A901417A.jpeg.0b4b7477bcbb8b9e5e94dd5644939598.jpeg
pfrederi
Video worked Robbie..
Pullstart
Sounds pretty decent...  how long had it been sitting?
12 hp Kohler
:handgestures-thumbupright:
The PO said it had been sitting 4 or 5 years. That worried me a little but it had good compression and it doesn’t smoke at all.
ZXT
Doesn't sound bad. With a little tweaking you'll be good to go.
I did the gas tank repair on mine with mixed results. The shutoff valve mod worked great, but the zip tie/soldering iron not so much. It was fine for a while but it cracked again on the top. Might not have worked the new plastic into it enough but I'm going to leave it be for now since it still works. If I ever find any implements for it and restore it, I'll probably have a metal tank made.
19richie66
Probably the age of the plastic. Aluminum is the way to go. 👍
  • Excellent 5
Aldon
Your son needs to start a side business!
Edited by Aldon
19richie66
If people didn’t mind paying for them, we would. They wouldn’t be cheap but would last a looooong time. It wasn’t a direct fit but pretty darn close. A couple slight mods to the lower mount but I think the upper holding strap may work. I made my own mounts. Not as much capacity as stock but still around 4 gallons. But , it doesn’t leak and I don’t have to worry about poking a hole in it. 👍
Edited by 19richie66
  • Like 4
  • Excellent 3
Aldon
And it adds Bling!!!!
  • Haha 5
  • Similar Content
    • tractorboy79
      By tractorboy79
      I was looking around on ebay and noticed that hydraulic actuators from John Deere 312, 317, etc models appear to be Identical to a Gt14 or d series lift cylinder. My question is would a new cylinder from ebay be able to replace one that is on a gt14 or d series?
      Images below of cylinders to show similaritys.
    • wh315-8
      By wh315-8
      I have a question about the 69’ model. I took my tank out to work on carb easier. A couple weeks later as I put it back together & after cleaning everything; I replaced the white weatherstripping that was at bottom of tank and on the corners of the strap. Seems to be all that holds it in place. Because the strap around the tank will not go around the metal bracket on bottom and fit the tank. And even if it did the strap would only line up with the bracket mounting bolts which would be in the way. What did I miss? Didn’t pay close enough attention when I took it apart and can’t see in the parts diagram where the strap does go around the bracket. The weather stripping is tacky enough that the tank stays in place and it is a made to fit perfectly in position. Just seems that the metal strap is pointless.
    • tractorboy79
      By tractorboy79
      I have a old gt14 and the plastic plates or control panels are way past their prime, and I saw someone was remarking them with a 3d printer a little while back and I was looking to se if I could find the file but no luck. If anybody has info that would be amazing. Thanks for your time and anything helps.
    • Rob R
      By Rob R
      I am currently doing a ring, piston, hone rebuild on a K 321 off a Ford LGT 145 Tractor  on this machine they actually welded the rails to the bottom pan (see pics). My intention here is to put this puppy in a red machine (312-8 or GT14). I definitely have the small pan with the expanded bottom for the long dipper.
      Here's my questions:
      > Can I carefully remove the rails from the pan, cutoff the old front axle mounting bracket(s) and then drill holes in  the flanges to mount  to the Wheel Horse rails.
      > Since the engine is side mounted will the expanded bottom fit between the standard Wheel Horse rails?
      > If not possible to make this old pan work what flat pan would work and do I need to get the expanded bottom one (big dipper}
      > any recommendations here would be appreciated don't want to go down to many blind holes here...….
      Thanks much!
    • swisstrac
      By swisstrac
      looking for info/help re securing a front wheel bearing/race for  GT14/ 1971;  any info would be much appreciated..
