Mark himelick 0 #1 Posted April 10, 2019 I need a new shaft for my d180 rototiller. I need the shaft or someone that can mill me one. The shaft that goes into the gear assembly on the rototiller. The pinion shaft. All but one tooth has broken off Share this post Link to post Share on other sites
Pullstart 63,343 #2 Posted April 10, 2019 I can’t help you with your D series tiller, but to @Mark himelick!! 1 Share this post Link to post Share on other sites
Tractorhead 9,065 #4 Posted April 10, 2019 (edited) Welcome you had a Pict from? A Pict. somtimes tells more than several Words. maybe it can be upwelded and reworked by Mill, to remove the caries your shaft have. did you search for that shaft? Edited April 10, 2019 by Tractorhead Share this post Link to post Share on other sites
Sarge 3,464 #5 Posted April 10, 2019 Your options are to find a good shaft - or take the existing, damaged shaft to a machine shop that can cut gears and be well prepared for the cost. Might want to give some of the tractor graveyards a call. Sarge Share this post Link to post Share on other sites
