bc.gold
Centrifugal Clutch
bc.gold
I was expecting an electric clutch for a project, putting one of my diesel engines to work on an fairly large air compressor but this centrifugal one will do the job.
With the electric clutch would have wired it to the pressure switch to cut out at the desired pressure, ca not recall the name of the other unit that works off of tank pressure that cuts the engine idle down anyhow that will release the centrifugal clutch when the engine comes back to an idle.
This clutch came from a Thermal King reefer with a Yanmar diesel it will now be coupled to a Mitsubishi three cylinder rated at 25 hp.
bc.gold
This is what I have in mind.
Air Compressor Pilot check valve unloader combination gas discharge 95-125
