dwhjelm 19 #1 Posted April 9, 2019 I have a 1989 wheel horse 414-8. What deck models will fit this tractor? The deck that was on it is the 37" side discharge and the tires rub when turning. I would like to find a larger deck that fits this tractor. Thanks. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,033 #2 Posted April 9, 2019 You can download the attachment list for your tractor here These are what were supplied in 1989 but you are not restricted to just these. Older back to 1973 and up to the last in 2007 will fit. They did not change in the way they connect to the tractor. Garry 1 Share this post Link to post Share on other sites
clueless 2,976 #4 Posted April 9, 2019 36" RD, 36" SD, 42"RD, 42" SD and 48"SD after 1973 will work. The mule drive and belt for the 37" won't work with the other decks. You can change one of the pulleys on the mule drive, but you will need the right belt for what ever deck you get. 2 Share this post Link to post Share on other sites
The Tuul Crib 7,336 #5 Posted April 9, 2019 9 minutes ago, clueless said: 36" RD, 36" SD, 42"RD, 42" SD and 48"SD after 1973 will work. The mule drive and belt for the 37" won't work with the other decks. You can change one of the pulleys on the mule drive, but you will need the right belt for what ever deck you get. 1 Share this post Link to post Share on other sites
Lee1977 6,643 #6 Posted April 9, 2019 2 hours ago, The Tool Crib said: I think they had two different models of the 37" deck mule drives one with two v-grooves and one with a v-groove and a flat. 1 Share this post Link to post Share on other sites
kick 59 #7 Posted April 10, 2019 10 hours ago, Lee1977 said: I think they had two different models of the 37" deck mule drives one with two v-grooves and one with a v-groove and a flat. I attest that the mule drive on my 310-8 has one flat and one v groove pully for the 37” SD deck. Share this post Link to post Share on other sites
dcrage 627 #8 Posted April 10, 2019 Just to be sure; your mule drive will work with other decks Share this post Link to post Share on other sites
