Mudrig150 313 #1 Posted April 8, 2019 I was working under my John Deere 317, under the rear end trying to find the drain plug. With one tire off, and the axle on jack stands, I THOUGHT it was secure. I slid out from underneath it, and barely leaned on it and the dang thing fell off the stands onto the floor. As it turns out, the stand on the side with no tire I was using was horribly bent and it completely fell over when I leaned on it. The lugs also fell out so the other tire came loose. That could've ended in disaster, especially since the rear end weighs well over 150 pounds... My frail little teen body would've definitely been crushed (I can only lift like 60 pounds). My brother and grandfather were there but not in the shed, and they were out for an hour and a half, so good thing I didn't get crushed. 1 5 Share this post Link to post Share on other sites
peter lena 9,053 #2 Posted April 8, 2019 very lucky on that, hope its a lesson well learned , years ago a friend lost his father in law to a bumper jack. next time you will go over the DETAILS OF WORKING UNDER A MACHINE , think safe, pete Share this post Link to post Share on other sites
bottjernat1 2,190 #3 Posted April 8, 2019 Glad ur ok! Ive been working on my 1981 317. almost done with it. couldnt emagine it falling on me. I bet you had a change of pants on that one! 1 Share this post Link to post Share on other sites
EricF 589 #4 Posted May 27, 2019 So many of us are trained to think (relatively) safe and never work under a vehicle supported by just a jack -- always use stands. But stands have their own safety issues that get passed over or forgotten. I'll always inspect the stands before putting them under the vehicle. Only takes a few seconds to check that nothing's bent or cracked, and they're latching correctly. A few seconds of inspection can save you. That and always check that the stand is stable and has a good hold where the vehicle rests on it. I won't get under unless I've pushed and prodded a bit to make sure it's actually stable! Sometimes a jack or a stand can't safely stay located under a load by itself, but some scrap wood blocks or cribbing makes all the difference! 1 Share this post Link to post Share on other sites
WHNJ701 4,165 #5 Posted May 27, 2019 I was taught once it's up on stands before you take the tires off, give it a good shake ams shove 2 Share this post Link to post Share on other sites
JCM 9,992 #6 Posted May 28, 2019 I used jack stands for years working on my 70 Chevelle SS and on my 70 Dodge Challenger and always backed them up with 8-8-16 concrete blocks with 2 by stock to make up the difference,never can be to safe. 1 Share this post Link to post Share on other sites
Mudrig150 313 #7 Posted May 28, 2019 So I inspected the stand and asked my pap, and as it turns out, that stand's failed before! The stupid thing bent and when he tried bending it back, the leg broke off, so he just welded it back together. I guess that stand's going in the trash. Share this post Link to post Share on other sites
