ihc57 0 #1 Posted April 7, 2019 im trying to help a family member out. and not having much luck. he has a snapper with a bad deck and I have a 312 with an extra deck I don't need I was wondering is I could just swap the hard where brackets from the snapper to the wheel horse deck. there both 42 inch decks. I think it could work. thank you in advance. Share this post Link to post Share on other sites
peter lena 8,583 #2 Posted April 7, 2019 don,t know if that will work , best to put decks side by side and see if it will work , every deck is different , as is every tractor drive set up . might be too much to do the swap. jmoo . let us know, pete Share this post Link to post Share on other sites
WVHillbilly520H 10,373 #3 Posted April 7, 2019 Snapper and TORO are 2 separate companies, I don't see where this would be an easy swap pulley size (diameter and height) not to mention how and where the lift carrier hardware bolts/mounts to, you would probably better off finding some other MTD made lawn tractor mowing deck...JMHO. Share this post Link to post Share on other sites
pacer 3,168 #4 Posted April 7, 2019 Most things like this CAN be done, but the question is whether its practical. I'm thinking that it would get complicated pretty quickly and put a lot of work into it only to realize "it just aint gonna work!!" Share this post Link to post Share on other sites
ihc57 0 #5 Posted April 8, 2019 thanks for the impute I just haven't seen much for used snapper decks. that being said. the time it would take to do it and summer being short and fishing to be done. im going to have to choose fishing. thanks again Share this post Link to post Share on other sites
