Similar Content
By Jayoutdoors
hey there I would like to install a ball and pull my boat and utility tractor around the property. I don't feel as if the design of this drawbar style is built for that not to mention low height. What recommendations, bought or built do you have to help me out..
it would be nice to keep my tiller attachment on if possible.
also what did they use the bar coming from under seat for??
By n1defan
I am taking orders for the custom heavy duty hitches that Scott and I have been building.
1. regular hitch $150 + shipping
2. XI hitch $175 + shipping
3. custom hitch to your dimensions $150 - $200 + shipping depending on what you need and cost of materials.
extra plates and bolts $10 To mount hitch to tractor if you don't have a rear plow mount.
Any questions you can PM me or post here.
the larger of the two is an XI hitch
By windish62
New to the forum.
I just bought my first wheel horse, it's a c125 8 speed with a 10 hp k241 so it's been repowered I take it.
My concern is when rototilling in first gear low I cant just let the clutch out and let the tractor do its thing I have to keep in and out of the clutch to let the motor catch back up.
Is the motor tired or is the tractor underpowered?
I have not cleaned the carb or done anything to the tractor yet for that matter. Just trying to get a feel for it.
By Tim Fenn
I've just acquired a renovated C125 but unfortunately the drive belt got snagged with the mower deck belt (maybe because of incorrect fitment?). It looks like I'm on a steep learning curve! I've been trying to find out which belt to buy as a replacement. The belt I've just taken off is 94 inches but according to the parts manual I need a Toro belt part number 94 2501 which is 103 inches? The mower deck is a 42in rear eject. It's funny that the Toro belt has 94 2501 as the part number but is 103 inches & I apparently need a 94in belt? Any ideas?
By Southerncannuck
My starter really drags for a few revolutions (barely turns over) then it spins the Kohler K301 like a champ. I replaced the battery with a 390 CCA interstate.
I suspect the brushes are damaged from previously having an underpowered battery. Should I replace the brushes or replace the starter? Also, what is a reputable place to buy these items? I don't want to buy junk.
