lewis357
71 raider 10 transmission drive belt length
lewis357
hi i have a 1971 raider 10 kohler engine and i am trying to find the correct length engine to transmission  drive belt length , the old one is worn so the nearest replacement i have found is a B80 17 X 2030 LI  but it is a little to long a B79 is to tight and there is no adjustment in the motor mount bolt holes , can any one tell me  the original size or part no , thank you
Achto
:WRS:    I don't have the answer to your question, but someone that can help should be along soon.
Ed Kennell
:text-welcomeconfetti: to the :rs: Lewis.     I could not find your belt part number either, but it should not be necessary move the engine to adjust the drive belt tension.  The clutch pulley should be able to handle this adjustment.     Garry should be here soon to help with part numbers.
lewis357
hi  i thought the pulley would  cope but its either permanent drive or a slight slip under load , with the original belt and  marking the pulley position to the frame neither of the belts i have tried are near , the old belt was an original part about 20 years ago it's almost needing a b 79.5 !! unless its the width that's wrong
Ed Kennell
The correct width is critical to the correct operation. If the belt is too narrow, it will sit too deep in the vee pulleys.      One other note is the belt guard must be installed for the clutch to operate properly.   The belt must be supported by the belt guard  to prevent contact with the engine pulley and allow the belt and transmission pulley to stop turning.
Can you post pictures of the clutch pulley and belt arrangement.     There is also a possibility thee is a pin sheared in the clutch pulley shaft that is not allowing the clutch to operate properly.
lewis357
it all worked fine with the old belt which is cracked through age and has worked fine for many years i only wanted to change it as part of a pre season service and with it back on all is ok i am sure its the width thats wrong
pfrederi
Drive belt is WH#7473    5/8" wide 82" long
daveoman1966
Drive berlt # 7473..   here for about $25 new.  https://www.psep1.biz/arinet.asp?aribrand=TO#/Toro_Consumer/1-0301%2c_Raider_10_Tractor%2c_1972/14.000_DRIVE_BELTS%2c_PULLEYS_(PLATE_14.1)/1-0301-520-1972/A-5309-5309009A-00013
I have a good used one for $15...shipped.  No cracks and the material is slightly worn.
lewis357
than you the B section belt i have is 17mm wide not the 15 .875 / 5/8 it should be
gwest_ca
The 1971 drive belt dimensions have been added to this page. Click on the picture.
The manual you can download covers most of the 1971 tractors and the Raider 10 is identified in the manual as model 10R.
More info on your tractor. Click on the fuzzy picture
Garry
